Exhaust stud size question |
ChrisReale |
Feb 11 2003, 12:28 PM
I am replacing one exhaust stud. Brad told me Zims sells a stud that half of it is oversized to make up for the stripped threads in the head. My questions are1) What size should I get (just to be clear), and 2) Is there any installation tricks I should know about before doing this. (IMG:style_emoticons/default/confused24.gif) Thanks (IMG:style_emoticons/default/mueba.gif)
Mueller |
Feb 11 2003, 01:16 PM
Which oversized stud to use mostly depends on the diameter of the hole after the stud has been yanked out of the head.....You'll have to measure the hole to see if you can get enough material to safely tap the head.
I've retapped for a bigger diameter stud and I have also HeliCoiled for the stud. I'm pretty sure the stud is normally 8mm/8mm in diameter and that 8mm/9mm and 8mm/10mm studs are available If you feel comfortable doing the Helicoil route, just get another 8mm/8mm stud |
tryan |
Feb 11 2003, 01:22 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
check out the ssi thread on the pp 911. john walkers jig for exhaust stud drilling looks effective, cheap and cool.
getting the hole straight is what i f up. |
Feb 11 2003, 01:28 PM
Not Mueller.... He just don't know when to stop drilling!! (IMG:style_emoticons/default/wink.gif)
The studs are also available at your local VW Bug shop, and very possibly also the dealer. You can imagine that this is a common problem with Bugs... --DD |
seanery |
Feb 11 2003, 05:02 PM
What about case certs like they do on 911 mag cases?
Will that work for this? |
Feb 11 2003, 11:35 PM
If I recall correctly, there isn't really enough room to use those.
--DD |
BenNC |
Feb 27 2003, 04:28 PM
Member Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 |
When I pulled off my exhaust and the replacement exhaust I got about a 50:50 ratio of nuts coming off studs to studs coming out of head. Everything seemed to come out smoothly.
Is it in by best interests to tap for a 9mm/8mm or can I just replace with 8mm/8mm? If I can go with the 8mm/8mm, where can I get them? My local shop sells the 9mm/8mm. Yes, jdogg I'm working on replacements for you too. (IMG:style_emoticons/default/smile.gif) |
Rouser |
Feb 27 2003, 04:49 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
I just recently had to replace a pulled exhaust stud.
Get a 8mm Helicoil (or kit), the recommended drill bit (sorry, don't remember the oddball size) and a 8mm/8mm stud from any VW shop. Heck, sometimes you can pick out the alumi-ni-um-numi-num from the stud and reuse it; your call. Chances are you WON'T have to tap out to the larger 9mm size if you can help it; the 8mm Helicoil and stud will work out fine. (IMG:http://www.pelicanparts.com/ultimate/image_uploads/WavingFlag.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 11:32 PM |
