Taped or cone shaped tubing for exhaust?, any tips on making this from flat stock? |
Mueller |
Nov 10 2005, 06:16 PM
For the turbo, I need to go from a 2.125" ID to a 1.5" ID from the header collector to the turbocharger.
I cannot find anything off the shelf with these odd sizes so I looks like I'll be making something.....think a sheetmetal roller will make this? Attached image(s) |
Aaron Cox |
Nov 10 2005, 06:18 PM
post a pic of your turbo. plz
it doesnt have a flat base that BOLTS on to a flange? seems losing an inch in ID would kill some performance.... turbo too small? |
jd74914 |
Nov 10 2005, 06:24 PM
You could weld the flange onto that piece (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) wouldn't loosing an inch actually force the gases into the turbo at a higher pressure so it would spool better? |
Andyrew |
Nov 10 2005, 06:25 PM
he wants spool up...
Looks doable to me... as long as the sheetmetal can hold the pressure and heat without warping to bad. |
Aaron Cox |
Nov 10 2005, 06:27 PM
sorry, im a turBONEHEAD
also.... wouldnt that create excess backpressure? and as raby said, the exhaust is the limiting factor of power.... just thinking aloud. |
Mueller |
Nov 10 2005, 06:31 PM
turbo next to 1"x2"x3" block for comparison
according to the data I have, it's good for close to 170hp (while still being efficient)...since it's going on a bone stock 1.8, I'll be well under that limit Attached image(s) |
Mueller |
Nov 10 2005, 06:33 PM
I think most of Jakes turbo applications are also pushing the limits....I'm looking just for a few more bolt-on ponies, not trying to break any records...I'm sure they'll be flaws in the design and execution, but hey, thats part of the fun.... |
Andyrew |
Nov 10 2005, 06:37 PM
It would put more pressure through the turbo spooling it up much quicker...
btw for refference, the stock 944 turbo's inlet for the turbo is just under 2in. and it spools up at 2.5k-3k depending on gear and load. Im guessing this turbo would be efficient from 2.5k to 5.5k... due to the smaller motor. Im sure mike ran the numbers.. |
TimT |
Nov 10 2005, 07:17 PM
ummm Burns use one of these, then get a stainless pipe reducer or bushing from somewhere like McMaster cut the Burns transition where it matches the dimension you need...
TimT |
Nov 10 2005, 07:19 PM
double oops, just get the burns RD150 its 1.5" on one end and 2.5 on the other cut off where it is 2.125" and make up the rest of the length with straight tube
Trekkor |
Nov 10 2005, 07:55 PM
I just came from the plumbing isle, I wish I saw this first. (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif)
sorry... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
McMark |
Nov 10 2005, 08:17 PM
One word...... BOOOOOST!!! (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) Just kidding you Mike. Hey, wait a second, just cast something. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Or CNC mill it. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) I think I'm done joking..... sooooo, how thick of sheet metal are you thinking? I know you can get adapter exhaust tubing, but it's more of a step down than a taper. |
McMark |
Nov 10 2005, 08:18 PM
What you really need are some sort of heads with extra cooling to handle your tubo induced heat.. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Mueller |
Nov 10 2005, 09:25 PM
didn't want to spend 21 bucks, but it'll save me the time and hassle of trying make my own...thanks |
ChrisFoley |
Nov 10 2005, 11:48 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Buying one from Burns will be about the cheapest way to get one of those. I don't think you can roll something like that in a slip roller - the id is too small. I have a taper mandrel for my stub pipes but it only goes from 1 1/2" up to 1 3/4". It takes a lot of pressure to push the mandrel into a piece of .065" wall SS tubing. |
bhfast |
Nov 11 2005, 11:02 AM
live it loud, balls out Group: Members Posts: 83 Joined: 30-December 02 From: Chandler, AZ/Daytona Beach, FL Member No.: 48 Region Association: Southwest Region |
mike, what turbo are you using
B |
fiid |
Nov 11 2005, 11:14 AM
I think your approach is viable apart from the shaping side. I bet you can buy something that will save you the effort though.
One place where you will need to do this is on the output of the turbo. Ideally you are going to want quite a large pipe on the turbo output and then taper down to your output pipe size. This helps create turbulent flow - which is good (according to the turbo book I have (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ). BTW - if anyone wants to do a turbo project I have 3 turbos at home that would be suitable for a 914 motor. Fiid. |
Hydra |
Nov 11 2005, 11:25 AM
Quia nominor LEO Group: Members Posts: 162 Joined: 11-December 04 Member No.: 3,261 |
Turbodynamics laws say that if you taper it, it would actually have a HIGHER velocity but a LOWER pressure, bernoully's law IIRC. but i hink a turbo needs higher gas velocity and not pressure... right? |
Mueller |
Nov 11 2005, 11:36 AM
It is a stock replacement turbo from a Mitsubishi GT3000/Dodge Stealth Twin Turbo V6 Since I have 2 turbos, I am making 2 of everything with hopes this works pretty well and some other sucker, err I mean 914 person* would want to purchase the other one as a Mickey Mouse Engineering kit (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) *it'll offered to a members son here 1st since his dad is helping with the laser cutting of some of the parts..... |
bhfast |
Nov 11 2005, 11:44 AM
are you just plugging the water cooled veins to the bearing section, using oil only? or using some kind of water cooling for the turbos also. I working on a twin turbo six set-up, and have not figured out if I will run extra cooling yet. I'm looking at those stealth turbos, as well as garrett gt15 and kkk ko3's. money will probably be the determining factor.
B |
Lo-Fi Version | Time is now: 17th May 2024 - 08:15 PM |
