Bursch exhaust questions |
914zim |
Aug 15 2003, 08:44 PM
Still pretty clueless... Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Hey guys:
A Bursch exhaust came with my pile-o-parts with my car. It says 914 73-74 on the sticker, but it doesn't look like it'll fit my car (76). It's got 2 inlets on each side and there is only 1 outlet on each side on my car. It looks like a really good setup that would look cool on my car, but I'm not sure I could make it work. Any ideas?? My current setup has a resonator and a muffler and it looks like crap (rusty). The Bursch setup only has 1 muffler (I think). I'm also wondering what emissions issues one might have with this arrangement if I could put it on my car. Any info on this would be appreciated. Thanks!! (IMG:style_emoticons/default/pray.gif) |
cgnj |
Aug 15 2003, 09:47 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
75-76 HE's are different than earlier HE's. Easier to backdate. Your halfway there. Carlos |
Bleyseng |
Aug 15 2003, 10:38 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Find the 73-74 Stainless steel heat exchangers and use the Bursch. You will pick up 7 hp with the change over.
Geoff |
rhodyguy |
Aug 16 2003, 04:02 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you will need a set of bellows/ valves, assorted j tubes, and branch pieces. you should be at the swap meet. you'd be 75% there parts wise.
kevin |
maf914 |
Aug 16 2003, 07:16 AM
As you said, the 75-76 has a muffler and a resonator. The California models had a catalitic converter between these while all others had a straight flanged pipe. If you don't have the cat I don't think changing mufflers or heat exchangers will affect emissions. The 75-76 exchangers are unloved for a reason. If you can find the parts, backdate to 73-74 2.0L heat exchangers with the Bursch. You'll probably like it.
Mike |
Part Pricer |
Aug 16 2003, 07:25 AM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
Andy,
Make sure which Bursch you have. If it just says "73-74", it is probably for 1.7-1.8 HEs. The 2 litre exhaust usually has a sticker that says, "73-74 2.0". |
914zim |
Aug 17 2003, 04:00 PM
Aw CRAP!
I just did a double check and it does NOT say 2.0L anywhere on the sticker. Does this mean that I can't even use this even if I changed to the earlier HEs? Man, that would suck!! Thanks for the replies guys! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
cgnj |
Aug 17 2003, 04:10 PM
Hi,
You have a pile of parts car. Does it Have HE's on it. Transplant every thing. Carlos |
914zim |
Aug 17 2003, 04:50 PM
Hi Carlos:
I wish my pile-o-parts was a whole car... although the missus wouldn't like it! All I have is the Bursch part. I'll have to take another look at my pile-o-parts. The other issue for me is the emmisions. I live outside of Milwaukee, WI and we do have fairly strict emmisions requirements. Anyway, for now I'm just trying to get my 914 running. It hasn't been started in over 4 years! I just got the gas tank back from being boiled and sealed inside. I am going to put it in tomorrow and maybe try to fire her up this week! Wish me luck! Thanks, |
Lo-Fi Version | Time is now: 29th May 2024 - 02:46 PM |
