> cleaning niksail/alusil P & C's, What type of chemical is safe
echocanyons
post Nov 11 2005, 03:02 PM
Sorry thats nikasil
porsche flat six BTW
I would like to clean my pistons and cylinders but I am concerned about damaging the coatings
Could I use an engine brite to clean them? How about brake or carb cleaner
goose2
post Nov 11 2005, 03:20 PM
I've been following a long thread on this on the Pelican 911 board (I'm rebuilding a 3.0)......Popular opinion is that hot soapy water and scotchbrite pads are best for the Nickasils. Don't know about pistons, but I've used Brakleen spray on them....with a soft brass brush on the crowns to get the carbon off. There's probably a better way short of bead blasting (don't blast unless you mask off everything but the top).
Mark Henry
post Nov 11 2005, 04:28 PM
that's what I do!
QUOTE (goose2 @ Nov 11 2005, 05:20 PM)
I doubt if most over the counter cleaners would hurt Nikasil. Doubt if I'd try easy-off though. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
I would stay away from and heavy acid or base cleaners just because of the Aluminum
I've bead blasted a 911 nikasil pressure plate...didn't even touch the nikisil.
Soap and water won't touch heavy grease...you use that for the final cleaning.
- Lo-Fi Version Time is now: 31st July 2025 - 02:38 AM
