> Brake cyl. hone, push tube seals
toon1
post Nov 11 2005, 09:03 PM
I am replacing the p/r tube seals in a 1.7 and am wondering if it is possible to use a brake cyl. hone to clean up the bores on the head?
bd1308
post Nov 11 2005, 09:26 PM
Sir Post-a-lot
if its a early 1.7, youd better hone good....the smaller pushrod tube seals are extinct now. only the larger 1.8,2.0 and late 1.7 seals are available. This requires a switch-over if you have the early ones.
b
Mark Henry
post Nov 11 2005, 09:40 PM
that's what I do!
The holes for the pushrods don't line up with the casting for the VC base. You will hit it and break your stones off.
bd1308
post Nov 11 2005, 09:41 PM
Sir Post-a-lot
QUOTE (Mark Henry @ Nov 11 2005, 09:40 PM)
i don't understand.....
b
Mark Henry
post Nov 11 2005, 09:47 PM
that's what I do!
Go look at your heads...the holes don't just go straight through....thats why the casting (head) has bumps on the bottom, to offset the pushrod tube holes.
sean_v8_914
post Nov 12 2005, 12:30 AM
Chingon 601
yes, a brake hone will work magic on teh pushrod tube sealing surface. use a dingle ball hone. I do this to my case also but it is , of course, a different size ball hone. O-rings like a really nice surface finish. do not hone it dry. use some oil
sean_v8_914
Chingon 601
they come in all sizes
Mark Henry
post Nov 12 2005, 06:08 AM
that's what I do!
I hate ball hones. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
I use a flapper wheel that's just a hair too big. Most tool shops have them.
Cap'n Krusty
post Nov 12 2005, 03:50 PM
Cap'n Krusty
QUOTE (bd1308 @ Nov 11 2005, 07:26 PM)
b
The seals are NOT NLA, and come in the 1.7 engine gasket sets. The Cap'n
- Lo-Fi Version Time is now: 30th June 2025 - 10:03 PM
