> couriosity killed the 1.7, man!
toon1
post Nov 12 2005, 09:52 AM
I was just going to replace the p/r tube seals and thought, since I dont know the history of the motor ,I shoud pull the heads and check things out to make sure the thing is even worth using. With all the bolts off ,I pulled the head and then proceeded to pull the two screws that hold the tin on the c/c. while lifting the screw up the washer fell into the lifter hole and DINK!, DINK ! you gussed it ,right into the case.
So now what, is there any way to get it out without splitting the case?
Can I leave it there?
toon1   couriosity killed the 1.7   Nov 12 2005, 09:52 AM
Headrage     Nov 12 2005, 10:05 AM
SpecialK   You might try and fish around with a telescopic ma...   Nov 12 2005, 10:07 AM
jsteele22   You might try to fish it out using a chopstick...   Nov 12 2005, 01:22 PM
Andyrew   CHOPSTICKS WHERE A JOKE..... dont try it.. funny ...   Nov 12 2005, 01:28 PM
Tom Perso   How does the motor look? If it's marginal, I...   Nov 12 2005, 01:33 PM
DNHunt   I lost a wavy washer down a lifter bore. I tore it...   Nov 12 2005, 03:03 PM
McMark   1.7s shouldn't have a windage tray. Here...   Nov 12 2005, 03:22 PM
toon1   the motor looks worn but might be worth the time a...   Nov 12 2005, 05:55 PM
Tom Perso   Run it. Oh, maybe try doing the tasks mentioned a...   Nov 12 2005, 11:01 PM
r_towle   take the sump plate off....find it. Rich   Nov 12 2005, 11:13 PM
toon1   How much is visable by taking off the sump plate?   Nov 13 2005, 12:22 PM
Bleyseng   not much but if you flush the motor with oil it mi...   Nov 13 2005, 12:25 PM
toon1   The more I look at it ,the more I think it needs t...   Nov 13 2005, 12:43 PM
Mark Henry   later 1.7's do have a windage tray   Nov 13 2005, 02:21 PM
Headrage     Nov 13 2005, 02:52 PM
anthony   Is the DVD different from the Bug Me Video Vol 8 v...   Nov 13 2005, 03:01 PM
Angelface01   I had this problem in my Bug once except with a 10...   Nov 13 2005, 06:13 PM
toon1   I found the washer, all I had to do was split the ...   Nov 13 2005, 11:12 PM
- Lo-Fi Version Time is now: 14th July 2025 - 08:46 PM
