| rhcb914 |
Nov 14 2005, 09:07 AM
member ![]() ![]() Group: Members Posts: 360 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
Can anyone tell me where I can get a set of wheel bolts and washers for an old set of Minilites? I tried Main Street Motor Sports and they told me that the bolts and washers are no longer available. I am only missing 2 wheel bolts and a thick and thin washer. Does anyone have 2 of these in their garage that they are willing to part with?
Here is a picture of the bolts. Attached image(s)
| rhcb914 |
Nov 14 2005, 09:08 AM
This is a picture of the bolt hole.
| GaroldShaffer |
Nov 14 2005, 10:31 AM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,645 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
Try paulspruell.com or Racing Stuff.com they both advertise in the SCCA magazine Sportscar that they sell panasport rims, I'm not sure but I think the bolts are the same style (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
I just put my minilites on the car, the PO of the rims (Hi Van (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) ) had them drilled to match the style of the regular 914 wheel bolts. They are a little different but in a pinch I could use the regular 914 bolts. Attached image(s)
| rhcb914 |
Nov 14 2005, 02:50 PM
I'll try those 2 places. I guess my other option would be to have the bolt holes machined to accept the 914 wheel bolts. Does anyone know of a place in the Boston area where I could get this done?
-Rob |
| r_towle |
Nov 14 2005, 09:49 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
hey,
try len over at autosport engineering in stow. or try shine racing in walpole. Or in a pinch little foreign car garage (watertown) the owner races 914's (go there to see some old and cool ferraris. Get your car corner balanced and aligned there too...one of the few in the area that will touch a 914 Or KTR in Ayer (same as above, but more eye candy...bring Greg and get the VIP tour. Or....millis used auto (owner is an ex 914 scca racer...now he races custom open wheeled jobs..) |
| spare time toys |
Nov 14 2005, 10:38 PM
hooked on grilling food. ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
I got these that may work for you. It has a stud you screw in and then the unt. I only have 8 of them though.
| maf914 |
Nov 15 2005, 09:39 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
Revolution Wheels use a similar bolt with a thick flat washer. If your leads for Minilite bolts don't work out, you might call Revolution and ask them. Both brands are British so there may be some similarity.
| rhcb914 |
Nov 15 2005, 09:41 AM
Hmm those may actually work. What is the OD of the shank? The ones I have are .620.
| URY914 |
Nov 15 2005, 11:18 AM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,624 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Those things are crap. Can't put any torque on them or they'll trist right off. I've done two pretty easliy. |
Lo-Fi Version | Time is now: 1st May 2026 - 08:14 AM |
