Mueller bearing install and 5 lug conversion, The time has come |
Leo Imperial |
Nov 17 2005, 01:48 PM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
So I won these parts at the WWC05'. I didn't even know at first what they were, but it didn't take long for the flock to move in and start making offers. Well I decided to do some research and I started collecting parts.
The front end has all been removed including the steering assembly. Turbo tierods will be part of the rebuild. The current swaybar is a 22mm adjustable upfront and will remain. I am keeping the stock 18mm torsion bars and a-arms. Everything else is being refreshed or replaced. When the front is done the rear will be converted to 5 lug and a rear swaybar will be installed. Also if they can be obtained a set of Mueller bearings. So here is the first set of pictures and questions fo Mike. Attached image(s) |
Leo Imperial |
Nov 17 2005, 01:51 PM
So here is the test fit in pictures.
Attached image(s) |
Leo Imperial |
Nov 17 2005, 01:52 PM
Perfect fit!
Attached image(s) |
Leo Imperial |
Nov 17 2005, 01:53 PM
I mean this is a perfect fit.
Attached image(s) |
Leo Imperial |
Nov 17 2005, 01:54 PM
Washer
Attached image(s) |
Leo Imperial |
Nov 17 2005, 01:55 PM
Roller
Attached image(s) |
Leo Imperial |
Washer
Attached image(s) |
Leo Imperial |
Nov 17 2005, 01:57 PM
The bearing
Attached image(s) |
Leo Imperial |
O-ring
Attached image(s) |
Leo Imperial |
Nov 17 2005, 01:58 PM
And the front mount.
Attached image(s) |
Leo Imperial |
Nov 17 2005, 02:00 PM
Now to grease it all and do the actuall install.
Any advise from the peanut gallery. Mike is this looking like the correct approach? BTW - everything fits perfect. No forcing and no play. Attached image(s) |
Mueller |
Nov 17 2005, 02:01 PM
Look'n good...make sure you lube the living daylights out of the bearings before the final install..........
Leo Imperial |
Nov 17 2005, 02:03 PM
Is this the type of grease you would use or should I get something else?
maf914 |
Nov 17 2005, 02:19 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I'm just a casual observer of the various bearing threads from the past, but I thought Mike or another bearing user had recommended marine grade grease (boat trailer wheel bearings) for water resistance. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Leo Imperial |
Nov 17 2005, 02:25 PM
That was what I had read also.
This stuff makes the same claims as the others on the shelf (water proof). The other option is synthetic, but is that really neccessary? |
Mueller |
Nov 17 2005, 02:27 PM
that looks like standard wheel bearing grease which should be fine, I've never run into a wheel bearing grease that is water soluable (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) the main difference with marine grade grease is the protection from thermal shock when backing your trailer into the water after a long drive...(read it someplace, how true, no real idea) |
airsix |
Nov 17 2005, 02:39 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Does the sleeve that the large bearing runs on have to be epoxyed to the arm to keep it from walking or spinning?
-Ben M. |
McMark |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Part of the marine grade grease recommendation was that it's much "stickier" than other greases and seems like it would stay in place longer.
Aaron Cox |
Nov 17 2005, 02:40 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
good question.... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Leo Imperial |
Nov 18 2005, 02:18 AM
I have alredy done the install with this shit.
Should I be concerned? |
Lo-Fi Version | Time is now: 17th May 2024 - 06:21 PM |
