More Power, Tired '75 1.8 |
19144jt |
Nov 18 2005, 05:24 PM
Member Group: Members Posts: 176 Joined: 19-September 05 From: Grass Valley, CA Member No.: 4,829 |
Hi,
I've got a 1975 1.8 that still runs pretty good but is getting tired. I am tryng hard to keep the car original so I would like to keep the fuel injection. When I rebuild the engine, am I limited to staying stock (for purposes of keeping the fuel injection) or are there some things I can do to get mild (or better) HP increases and not have to carburete? Any ideas would be appreciated. John |
dlo914 |
Nov 18 2005, 05:40 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
im not quite sure, but i was headed in this direction before i found a mid-life FI 2L. i was going to have the jugs bored out to a total of 1911cc, and then go w/ the 96mm kenneth black pistons. As for the crank and arms i was told to find some off a 2L. I was also told the stock 1.7 FI system would be able to compensate for the extra CC's. But then what do i know..im still a newbie (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Mueller |
Nov 18 2005, 05:41 PM
backdate the exhaust to a '73/'74 2.0 or install 1.7/1.8/2.0 SSI stainless steel heat exhangers
if in good condition, re-bore to 96mm to get to a 1911 (Jake Rabys shop can do that and supply the pistons) not too much more can be done, the AFM does not like wild cams..... |
Al Meredith |
Nov 18 2005, 06:02 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I've got a set of 1.8L euro pistons. They are NEW in the box and have a domb on top just like the 1.7 piston. The high compression will work with the stock FI. I really want to sell them with a set of rebuilt 1.8 heads. They have opened up exhaust ports and duel valve springs. Len Hoffman installed oversized seats to be used with the duel springs. For $850 I will through in a set of lightened rods. Al
sean_v8_914 |
Nov 19 2005, 12:53 AM
I ran 96 mm flat top pistons on my 1.8 L-Jet. I liked it. that car lives in WA now
bottomend |
Nov 19 2005, 01:35 AM
Member Group: Members Posts: 180 Joined: 27-August 05 From: LA,Ca Member No.: 4,683 |
the absolute easiest way to gain HP is to have the entire rotating assembley balenced. This allows for less friction. Less friction allows for less heat. Less heat means more HP. More HP means more VAROOOOMMMMMM!
You can increase the CR to a point. From what I understand, L-jet cant take as much added compression as a carbed system but it's better than an older D-jet system in this reguard. You can add displacement as was mentioned before. The most common way is to add the crank from the 2 L engine and bore out your 1.8 L piston to 96 mm. You'll end up with 2056 cc and with a good cam you can expect around 110 hp with a good head rebuild. Nothing fancy on the heads, just slightly larger valves and good sealing to the cylinders. Before you start spending money, ask lots of questions and buy some book ect and learn or else you'll waste $ and time. |
Lo-Fi Version | Time is now: 26th May 2024 - 06:17 AM |
