Front suspension coversion Q's |
greg derr |
Nov 18 2005, 09:04 PM
Newbie Group: Members Posts: 4 Joined: 26-December 02 Member No.: 15 |
Winter project. I just bought 1985 911 struts spindles brakes and rotors, do I need any other parts for the conversion on my 73 teener? Thanks. Greg
Bleyseng |
Nov 18 2005, 09:20 PM
New bearings and seals
check the rotors out you might need new ones new pads Shocks |
Eric_Shea |
Nov 18 2005, 09:54 PM
Should be good to go with the 73/85 swap.
I agree with the above. Maybe get some new bearings while you're in there and the others are unknown. New strut inserts? Through body bar and weld some u-tabs on your a-arms? DWD sets in and you strip the tub throw the entire car into 13 boxes and set her on jackstands for the next decade?? |
johnmhudson111 |
Nov 18 2005, 10:11 PM
Member Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
Pick up a couple of bail joint pins I destroyed the threads on my orginal pins when I did my struts.
Allan |
Nov 18 2005, 10:16 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Mine started with an oil leak. Ended up with a new motor and complete rustoration, then traded everything for a /6 conversion... Good luck... |
pete-stevers |
Nov 18 2005, 11:27 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
While you are at it ...if the budget allows....perhaps a set of turbo tie rods.....and perhaps a 19mm master cylinder....but like i said .....perhaps (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
bondo |
Nov 18 2005, 11:33 PM
Only 13? I've got at least that many plus most of a backyard shed! I hope to beat the decade though. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:59 AM |
