greg derr
Nov 18 2005, 09:04 PM
Winter project. I just bought 1985 911 struts spindles brakes and rotors, do I need any other parts for the conversion on my 73 teener? Thanks. Greg
Bleyseng
Nov 18 2005, 09:20 PM
New bearings and seals
check the rotors out you might need new ones
new pads
Shocks
Eric_Shea
Nov 18 2005, 09:54 PM
Should be good to go with the 73/85 swap.
I agree with the above. Maybe get some new bearings while you're in there and the others are unknown.
New strut inserts? Through body bar and weld some u-tabs on your a-arms? DWD sets in and you strip the tub throw the entire car into 13 boxes and set her on jackstands for the next decade??
johnmhudson111
Nov 18 2005, 10:11 PM
Pick up a couple of bail joint pins I destroyed the threads on my orginal pins when I did my struts.
Allan
Nov 18 2005, 10:16 PM
QUOTE (Eric_Shea @ Nov 18 2005, 07:54 PM) |
DWD sets in and you strip the tub throw the entire car into 13 boxes and set her on jackstands for the next decade?? |
Mine started with an oil leak. Ended up with a new motor and complete rustoration, then traded everything for a /6 conversion...
Good luck...
pete-stevers
Nov 18 2005, 11:27 PM
While you are at it ...if the budget allows....perhaps a set of turbo tie rods.....and perhaps a 19mm master cylinder....but like i said .....perhaps
bondo
Nov 18 2005, 11:33 PM
QUOTE (Eric_Shea @ Nov 18 2005, 08:54 PM) |
Only 13? I've got at least that many plus most of a backyard shed! I hope to beat the decade though.
