New 2.0L Heads at PP |
Bleyseng |
Nov 19 2005, 10:48 AM
Anyone bought a set??
I thought these were long out of production? Are these some long lost stash? http://www.pelicanparts.com/catalog/shopca..._pg4.htm#item29 DD? (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
Demick |
Nov 19 2005, 11:50 AM
Interesting. The '75-'76 2.0 heads are almost $500 each cheaper than the '73-'74 heads. I thought the only difference between them was an EGR port on the lat model ones that is easy to plug. Are there other differences?
Demick |
Aaron Cox |
Nov 19 2005, 11:52 AM
late ones flow a little less on the exhaust side.....
the whole EGR thing requires some welding up make it as good as a 73-74 head |
Bleyseng |
Nov 19 2005, 12:02 PM
Huh Aaron? Why do you say that?
the different he's caused the drop in HP but the exhaust ports? |
Mueller |
Nov 19 2005, 12:05 PM
flow should 100% the same between the 2....the earlier ones are more "desirable" due to not having to plug the holes which are no big deal.....
seanery |
Nov 19 2005, 12:07 PM
How do the new heads by Jake & Len compare $$$-wise to the 73-74 heads at PP?
Cap'n Krusty |
Nov 19 2005, 12:27 PM
That's an air injection port. The EGR dumps into the intake at the air cleaner, AIS dumps into the exhaust port. It wouldn't make sense to dump exhaust into the exhaust. The Cap'n |
Bleyseng |
Nov 19 2005, 12:38 PM
They are around $1800 for a set |
914werke |
Nov 19 2005, 04:15 PM
"I got blisters on me fingers" Group: Members Posts: 10,070 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
For almost $500 differance per head Id weld up the late ones. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Aaron Cox |
Nov 19 2005, 04:45 PM
look at the exhaust ports.... one is smooth... one has a big hole in it for the AI stuff. the difference is there, not sure how much of a difference there is. if one were to weld up the hole from the inside, and machine it smooth... then they would flow 100 percent the same. Just my opinion fellas |
Teknon |
Nov 19 2005, 05:02 PM
The more I learn the dumber i think I am Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
The late ones also don't have the crankcase blowby hole. But can be drilled in. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Verruckt |
Nov 19 2005, 06:57 PM
Senior Member Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
For the price they are wanting, you could buy a used set, and send them to HAM and be money ahead. That's STEEP. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Mark Henry |
Nov 19 2005, 07:02 PM
Most likely they found a stash of NOS heads.
Some did and some didn't...I had a set that did have them and it looked quite factory. |
Lo-Fi Version | Time is now: 18th May 2024 - 09:40 PM |
