Chevy 350 or 327, Can someone give me a dimension? |
nick mironov |
Nov 20 2005, 10:59 AM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
Can anyone give me a measurement of the distance between the crankshaft face and the engine mounting flange for either a Chevy 350 or a 327 - if you have one out of a car?
I have a 283 and suspect that its configuration might be a bit different from the 350s and 327s that most of the conversion adapter plates are set up for. Note the bevel in the end of the crankshaft socket. I understand that 350s do not have such a bevel. A standard pilot bearing does not fit into the beveled receptacle - the bearing's back face must be beveled to match. (My 283 has a dimension of 43/64" - just a shade over 5/8") Attached image(s) |
Nov 20 2005, 05:07 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) sorry, dunno squat about v8s ...
but someone else might ... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Andy |
Type 4 Unleashed |
Nov 20 2005, 07:11 PM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
All, the outer dimensions on SBC are the same, 283, 302, 307, 327, 350. IN, your picture, the pilot bearing is already installed. Skline, has a 283 in his Chalon,Kennedy Adaptor. |
BIGKAT_83 |
Nov 20 2005, 07:56 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
The V8 adapter pilot bearing for the 283 crankshaft is different from a 327/350. The pilot bearings are different widths and the 283 does have a bevel to match the crankshaft. The bearing on the left is for a 283 and the one on the right is for a 350. (IMG:http://www.914world.com/bbs2/uploads/blog-1132536916.jpg)
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Bob (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
nick mironov |
Nov 23 2005, 12:23 PM
I have confirmed with Kennedy Engineered Products (KEP) that the standard crankshaft extension on all small blocks (265-350) is 0.70". I also checked this an a 350 and double-checked my 283. 0.70" is correct. The only difference is that the 283 (and maybe 265) have the bevel inside the crankshaft flange, and the larger engines do not.
skline |
Nov 23 2005, 02:28 PM
Richard is correct, I do have a 283 in mine, however, looking at the picture above, I have the pilot bearing on the right and I got it direct from Kennedy. I think it was $40.00 delivered. It fit right in and I had no problems what so ever. I did tell them it was for a 283 and they told me there was a special one for that so I am assuming they sent me the right one. It seems to be working so far. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Lo-Fi Version | Time is now: 7th May 2024 - 12:48 AM |
