Need wiring harness opinions |
JeffBowlsby |
Aug 18 2003, 09:18 AM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
“Hi Jeff,
Well, the new Ignition harness is installed. No problem. My harness was in bad shape. I had spliced here & there more than a few times. But still – I can't believe how different it now runs, especially when cold. Much smoother. Can you tell me why? Thanks Again, Gary” Gary bought a new harness and sent me this note today, I get comments like his regularly. All I can think of is that the old connections and wiring have built-up resistances and made for crummy electrical contacts. Maybe that’s why our dash lights are so dim? Any other ideas? |
Bleyseng |
Aug 18 2003, 11:24 AM
That and the grounding points are always rusty. New wire is always going to help fix electric problems.
Geoff |
GWN7 |
Aug 18 2003, 10:29 PM
The wires "rust" up into the wire from the connection points. Makes for resistance in the loop. And the plastic covering gets old/brittle causing electrical bleed across themselves.
Or it all the Aliens fault......... (IMG:style_emoticons/default/smile.gif) |
ChrisReale |
Aug 18 2003, 10:42 PM
A new wiring harness is on my list. My engine is a fresh rebuild, so why is my harness the original?? Because I didn't know Jeff offered this service until I was outta money (IMG:style_emoticons/default/huh.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 04:54 PM |
