JeffBowlsby
Aug 18 2003, 09:18 AM
“Hi Jeff,
Well, the new Ignition harness is installed. No problem. My harness was in bad shape. I had spliced here & there more than a few times. But still – I can't believe how different it now runs, especially when cold. Much smoother. Can you tell me why?
Thanks Again,
Gary”
Gary bought a new harness and sent me this note today, I get comments like his regularly. All I can think of is that the old connections and wiring have built-up resistances and made for crummy electrical contacts. Maybe that’s why our dash lights are so dim?
Any other ideas?
Bleyseng
Aug 18 2003, 11:24 AM
That and the grounding points are always rusty. New wire is always going to help fix electric problems.
Geoff
GWN7
Aug 18 2003, 10:29 PM
The wires "rust" up into the wire from the connection points. Makes for resistance in the loop. And the plastic covering gets old/brittle causing electrical bleed across themselves.
Or it all the Aliens fault.........
ChrisReale
Aug 18 2003, 10:42 PM
A new wiring harness is on my list. My engine is a fresh rebuild, so why is my harness the original?? Because I didn't know Jeff offered this service until I was outta money
