Front Sway Bar - How Much?, What should I pay and what size |
vesnyder |
Nov 22 2005, 01:36 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I am in the market for a front sway bar since I am tearing the front end apart and taking the gas tank out - what should I expect to pay for the complete setup and what size should I look for. The car will be mostly a Sunday cruiser with the eventual Auto-X and DE.
Allan |
Nov 22 2005, 01:38 PM
Stock front bars can be found for $100.00. I bought a 23mm adjustable Weltmeister for $200.00. You might check with Craig at Camp914 or Rich at HPH.
dlo914 |
Nov 22 2005, 01:40 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
here's a stock front sway bar on ebay, quite a bargain if it doesnt surpass the $100 mark: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMEWA%3AIT
STL914 |
Nov 22 2005, 05:12 PM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
I just pulled a factory bar from my 74 that's available. Only thing missing are the U-tabs for the A-arms. Open to any reasonable offer.
SLITS |
Nov 22 2005, 05:34 PM
Gary's is a good deal 'cause it has the reinforcing plates with it....The stock ones are welded in and you usually have to purchase them seperately.
vesnyder |
Nov 22 2005, 06:26 PM
Gary - I'll leave you a PM.
SLITS |
Nov 22 2005, 06:29 PM
You will still have to buy the "U" tabs and weld them on your "A" arms (unless your car has them).
Also, go to the winky board ( www.pelicanparts.com ) , download the sway bar bracket template and print it. This will tell you what size and where to drill the holes in the wheelhouse. |
elwood-914 |
Nov 22 2005, 06:36 PM
elwood-914 Group: Members Posts: 387 Joined: 29-December 02 From: Plymouth CA Member No.: 38 |
My 1.7 doesn't have a swaybar yet, but it does have the U tabs already.
SLITS |
Nov 22 2005, 06:38 PM
Get the door......It's UPS (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif) |
J P Stein |
Nov 22 2005, 07:45 PM
Get an adjustable AR bar. The 19 mm Weltmiester is decent and fairly inexpensive. IMO, anything bigger is too big....yes, Virginia, it's possible.....for the stock front end. With 140-150 lb rear springs this makes a nice streetable AX set-up. This was the most comfortable/controllable/easy to drive set up I ever had on my 914.....with some gud tires, of course.
bondo |
Nov 22 2005, 08:08 PM
I happen to know that your 914 has the U tabs, so no worries there. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
STL914 |
Nov 22 2005, 08:40 PM
PM sent.
Lo-Fi Version | Time is now: 7th May 2024 - 01:58 AM |
