944 steering wheel, will it fit a 914 hub? |
roverv8 |
Nov 22 2005, 09:57 PM
Newbie Group: Members Posts: 3 Joined: 22-November 05 From: Portland, OR Member No.: 5,171 |
Curious if a '85.5+ 944 steering whel will fit a 914 hub. Anyone know if the splines are the same? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Brando |
Nov 23 2005, 12:01 AM
I dont think so... diameter of the shaft is bigger on the 944...
Aaron Cox |
Nov 23 2005, 12:17 AM
ive seen 75 and up 911 wheels fitted before....
roverv8 |
Nov 23 2005, 01:28 AM
Thanks, all. I'll keep watching to see the consensus
roverv8 |
Nov 23 2005, 01:29 AM
thesey914 |
Nov 23 2005, 01:38 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
I've tried this and the answer is no on the 944 four spoke wheel I tried.
Jeroen |
Nov 23 2005, 07:19 AM
944 wheel has different splines
911 wheel (up to 89) has the same splines, but different offset |
brant |
Nov 23 2005, 09:33 AM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
944 does have a larger diameter shaft.
However, it is big enough that it can be turned down, cut to length and re-splined. I did it on my street car had a machine shop re-spline it for me and use a 4 spoke 944 (non-airbag) wheel on my teener. you have to shorten the shaft and measure twice so that the wheel fits nicely up to the dash. brant |
Brando |
Nov 23 2005, 10:00 AM
all that work and money -- find a choice sport wheel (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
brant |
Nov 23 2005, 10:15 AM
True.... but its the only porsche 4 spoke wheel'd 914 I've ever seen.... and it was more about trying to do something (sense of accomplishment) than it was about being easy brant |
thesey914 |
Nov 23 2005, 02:32 PM
Drat I thought mine was too!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I went the other route and attached another hub to the 944 wheel....but the leather wasn't too good and now have a 911 four spoke. Its worth doing as it feels just right. |
Brando |
Nov 23 2005, 04:02 PM
It might be easier to just take that portion of the steering column out of a late 944 and try to make them mate up. 85.5-on had the 4-spoke wheel, [i *think*] 90s on they got airbags driver/passenger. I guess then you'd need the steering collar and ignition switch stuff... hmm...
Maybe just take the splined end, cut it off, weld it onto the 914 column? |
Lo-Fi Version | Time is now: 7th May 2024 - 08:57 PM |
