roverv8
Nov 22 2005, 09:57 PM
Curious if a '85.5+ 944 steering whel will fit a 914 hub. Anyone know if the splines are the same?
Brando
Nov 23 2005, 12:01 AM
I dont think so... diameter of the shaft is bigger on the 944...
Aaron Cox
Nov 23 2005, 12:17 AM
ive seen 75 and up 911 wheels fitted before....
roverv8
Nov 23 2005, 01:28 AM
Thanks, all. I'll keep watching to see the consensus
roverv8
Nov 23 2005, 01:29 AM
thesey914
Nov 23 2005, 01:38 AM
I've tried this and the answer is no on the 944 four spoke wheel I tried.
Jeroen
Nov 23 2005, 07:19 AM
944 wheel has different splines
911 wheel (up to 89) has the same splines, but different offset
brant
Nov 23 2005, 09:33 AM
944 does have a larger diameter shaft.
However, it is big enough that it can be turned down, cut to length and re-splined.
I did it on my street car
had a machine shop re-spline it for me and use a 4 spoke 944 (non-airbag) wheel on my teener.
you have to shorten the shaft and measure twice so that the wheel fits nicely up to the dash.
brant
Brando
Nov 23 2005, 10:00 AM
all that work and money -- find a choice sport wheel
brant
Nov 23 2005, 10:15 AM
QUOTE (Brando @ Nov 23 2005, 09:00 AM) |
all that work and money -- find a choice sport wheel |
True.... but its the only porsche 4 spoke wheel'd 914 I've ever seen....
and it was more about trying to do something (sense of accomplishment) than it was about being easy
brant
thesey914
Nov 23 2005, 02:32 PM
QUOTE (brant @ Nov 23 2005, 05:15 PM) |
True.... but its the only porsche 4 spoke wheel'd 914 I've ever seen.... |
Drat I thought mine was too!!
I went the other route and attached another hub to the 944 wheel....but the leather wasn't too good and now have a 911 four spoke. Its worth doing as it feels just right.
Brando
Nov 23 2005, 04:02 PM
It might be easier to just take that portion of the steering column out of a late 944 and try to make them mate up. 85.5-on had the 4-spoke wheel, [i *think*] 90s on they got airbags driver/passenger. I guess then you'd need the steering collar and ignition switch stuff... hmm...
Maybe just take the splined end, cut it off, weld it onto the 914 column?
