Give me your knowladge..., 914 crossbrace inbetween 911 a-arms |
Nov 23 2005, 11:40 AM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) |
brant |
Nov 23 2005, 11:42 AM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Trev,
I'd try to assess how much (if any) flex your getting on the front mounting points. We didn't want to add a brace for weight purposes, but had cut out so much of the firewall (at the back of the cell) that we perceived some actual flex...... It really may not be a functional bar according to many. but we used a very light material to lessen the impact of adding 1 more bar. brant |
andys |
Nov 23 2005, 12:44 PM
So the suspension was at full droop when you witnessed this? Any idea if this still occurs with the wheels on the ground? Though it seems unlikely to me that the crossmember from a heavier and more powerful car would do this, I bow to experience. That said, perhaps the 914 crossmember is a structural part to the unibody where as the 911 unit is not. Maybe there's more there than meets the eye? I have both, but am considering the steel version only because it has provision to bolt on the protective pan. Andys |
Nov 23 2005, 12:52 PM
yes, full drop, no wheels attached. turned the steering-wheel until i hit the stop and when i applied some more force to the steering wheel at the stop, the aluminum cross member was (very obvious, visually) twisting ... now i don't know if it's supposed to do that or if i had a bad one (inspected it later, no cracks, looked good) but it was enough for me to go back to the stock steel crosssmember ... that's all. just good 'ole observation ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
Brad Roberts |
Nov 23 2005, 01:36 PM
They flex in a 914. You can argue all you want. I have seen people install them in their 914's and not make any brackets for the back bolt holes (support) Not good.
B |
Rough_Rider |
Nov 23 2005, 01:45 PM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
Cheers Brant,
The PO cut the entire floor pan out, gone nothing left. Then pop rivited a stainless or aluminium sheet which the cell is bolted too. his next solution was to get a 1/4" thick metal stock & bolted it too what appear to be oem a arm cover plates. Whole thing weighs 7lbs. I'm stripping the trunk now to fix up all the rust & re-weld, just wanted to see what i'd need to put back (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Lo-Fi Version | Time is now: 7th May 2024 - 08:02 PM |
