weberconversion, pics or help on installing |
billywalton |
Nov 23 2005, 10:08 AM
Newbie Group: Members Posts: 2 Joined: 17-November 05 From: HUNTSVILLE,AL Member No.: 5,143 |
i am installing a set of webers on a 73 914 1.8. the kit is from redline. does the bar attach to the front or back of carbs. i need pictures or a installed unit or detail info on how to hookup the carb throttle linkage. help.
Joe Ricard |
Nov 23 2005, 10:29 AM
Well don't know your linkage configuration but, with CB type linkage hex bar with arms on each end connected to reach rods that actuate the carb throttle plates.
I put mine on the front throttle cable pulls lever forwards from top of bar. This rotates hex bar and pushes arms down. this action pushes on and rotates the throttle plates by means of short link attached to throttle plate shaft. Rotation of throttle plates is towards the center of the engine. |
tommy914 |
Nov 23 2005, 10:38 AM
Life is a journey, enjoy every turn. Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
You can also mount them on the back of the carb with the throttle cable pulling forward from under the bar.
It really depends on how you fabricate the bracket that holds the cable, and how much room you have at the rear of the motor. On some motors the throttle crossbar arms will be too close to the back wall and rub. If you search a little you will find some engine pics with carbs. |
Type 4 Unleashed |
Nov 23 2005, 11:39 AM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Here's a pic, should give you an idea:
Aaron Cox |
Nov 23 2005, 11:54 AM
that linkage wont work.... arm needs to be on the top. |
maf914 |
Nov 23 2005, 12:06 PM
Maybe, or maybe not. I also depends on how the throttle arms are placed on the carb throttle shaft, i.e. on which side of the carb body. This dictates if the linkage is pushing down to open the butterflies or pulling up to open them. |
lapuwali |
Nov 23 2005, 12:26 PM
In short, it will go either way. I prefer having it to the rear of the engine bay, as it doesn't get in the way of the distributor to set timing. However, it can interfere with the trunk lid springs depending on how it's set up.
You really want the drop links to be as close to vertical as you can get them. If you splay them out to pull the arms up (as pictured), then you'll get unequal action at some point in the stroke that will be impossible to adjust out. |
Kargeek |
Nov 23 2005, 01:14 PM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
Here's how I did mine. Arms to the rear, simple cable bracket off the side of the carb. The CB linkage had two positions on the carb linkage stands to mount the cross bar- high and low- I used the lower position and cut down the stand. DH
Joe Ricard |
Nov 23 2005, 05:55 PM
DAng that's a clean engine compartment. Do you actually drive that thing?
Carlitos Way |
Nov 23 2005, 07:34 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Yeah. What he said!!!! |
Lo-Fi Version | Time is now: 7th May 2024 - 05:52 AM |
