aaaahhh..1 step forward, 2 steps back :( |
Mueller |
Aug 18 2003, 09:58 PM
So here I go and try to bolt my wheels on the front hubs and the mother-f'rs don't fit.......
opps....my fault...i turned down the diameter of the hubcentric ring of the stock hub but totally forgot to measure the hieght of it....new rims hubcentric feature are too shallow (by .200" or so) the worst part was that I already pressed in the studs and now I have to remove and replace them..... oh, this is for my Vanilla Rice project, Honda style Konig rims on re-drilled and studded 4x100 bolt pattern...... I shouldv'e kept the Fuchs (IMG:style_emoticons/default/smile.gif) i needed to vent, much safer to do it here than throw anything in the garage (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) |
Dave Cawdrey |
Aug 18 2003, 10:45 PM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
I had to run a 5/16 spacer up front to clear the dust cap area. The hub bore of the wheel is 2 mm too small. The wheel wouldn't sit flush.
16 x 7 w/ 205's and 5 inch back spacing. Got plenty room now !! THANKS AGAIN, EVERYONE !! Gonna go 225/55 or 60's and 1 inch spacers all around. |
EdwardBlume |
Aug 18 2003, 11:25 PM
What do you use for wheel studs??? Where can I get some that would work for my 2.0 Fuchs???
Mueller |
Aug 18 2003, 11:51 PM
Rob,
Dave and I both have press-in studs (I'm 99% sure his are) CB Performance carries Gorilla brand screw-in studs. I went to Gorillas site and they just list the studs as being cold-forged (not a bad thing) but I don't know how they compare to the factory parts. Being 14mm, they are considered oversized in the automotive industry ( a good thing ), heck, my 3300 pound Volvo only has 12mm studs. |
Jeroen |
Aug 19 2003, 04:22 AM
Lawrence |
Aug 19 2003, 06:32 AM
Got pics, Mike?
Lo-Fi Version | Time is now: 19th May 2024 - 06:44 PM |
