2.7 RS+ or 3.2 ? |
2.7 RS+ or 3.2 ? |
Eddie914 |
Nov 25 2005, 09:07 PM
Unregistered |
The 2.7 in my teener dropped a valve and went kablammo last August. I bought a repacement 2.7 only to find metal chips in the sump screen.
Should I rebuild the 2.7(s) to RS specs or install a 3.2? I have found a local 3.2 with 79k for $4,000 (complete except intake manifold). I don't think there is any way I'll be able to get the 2.7 rebuild done for less than $4,000 even if I perform all the labor. I've torn down the replacement 2.7 and the bad luck continues ... Alusil cylinders and chipped teeth on the countershaft chainwheel sprockets. How about a 3.2 with 40IDA Webers? What cams? I know 46IDAs would be better but I have the 40IDAs off the 2.7. Thanks for your input. Eddie |
nine14cats |
Nov 25 2005, 09:11 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Hi Eddie,
I'm really interested your thread as I am building a track only 914-6 and am debating currently between a 2.7 (2.8) or a 3.2. I've got Weber 40's in my garage, but I was wondering if they were too small for a 3.2. I hope you (we) get alot of answers! Bill P. |
d914 |
Nov 25 2005, 09:14 PM
sell the 40's and buy my 46"s...
seriously, street maybe,race motor???? I know a 2.5 that went to pmo 50's!! |
theol00 |
Nov 25 2005, 09:27 PM
Member Group: Benefactors Posts: 242 Joined: 22-January 04 From: Campbell, CA Member No.: 1,586 |
I have a 2.7 RS spec motor with approx 220 - 230 hp with Webbers 40 IDAs - all i have heard about bigger carbs is that people have trouble getting their cars running - the motor runs great is very torquee and has a great power band between 4000 - 7300 RPM - usually I can pull away and out-accellerate from 3.0 SC powered cars on the track. The motor I have, has been build by GD Racing in San Bruno, CA (Gary Dielacher) and has been around for a while - approx 30+ trackdays. and is very reliable. Like everything Gary has build!
McMark |
Nov 25 2005, 09:30 PM
I would think go for buying a running motor rather than rebuilding. Just getting new pistons and cylinders will eat up a lot of your $4000. Of course, the gamble is, how long will it last?
Aaron Cox |
Nov 25 2005, 10:33 PM
it all depends on what you want it to do....
me? racer? 2.7/2.8 streeter? 3.2 |
retrotech |
Nov 25 2005, 10:38 PM
retrotech Group: Members Posts: 470 Joined: 2-November 03 From: Mosier, Oregon Member No.: 1,302 |
Hi Eddie,
I have 2.8 with 46mm webers. I had the engine dyno tuned, and the 46 are now great on the street, awesome on the track. The intake noise alone is worth it. |
TimT |
There is no replacement for displacement...
OK lets all sing along now LOL |
J P Stein |
For the carbs, 40s should work fine. Anderson has a formula in his book for sizing vevturi. pg 149.
Cams? With stock pistons, you're kinda stuck for stock for either....tho some think 964 cams are better for the 3.2L and will fit....supposedly. The 3.2L has a problem with over revs.....the rod bolts are the weak spot......and it will bend every valve. The RS motor has a better chance but it's not bullet proof. I guess my advice is it really doesn't matter. If it's a track motor you should build it as such (or have it done) or risk the consequences. Were it me, I'd go to Jeff Hines and have a long talk with him. |
kdfoust |
Nov 26 2005, 12:06 AM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
I thought about the same kinda stuff. I already made my descision: 3.2 Motronic. It will be a track car with an eminately driveable powerband and pretty high reliability.
The high performance paths are pretty well defined for both engines (well that goes for any of the Porsche flat-6 engines). To me the big advantage to the 3.2 is that it already comes with a modern engine control system that can support significantly more power with programing changes. But for me, I'm not a carb guy...no interest in them at all. Either way you'll have some fun. Later, Kevin |
sixnotfour |
Nov 26 2005, 01:24 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
3.2 Check it out Before you buy it.
79k probably needs guides If its true , do it ,leave it stock , use the torque. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) problem finding the injection, .5-1 k I gots the carb stuff . Flywheel ? It will be a used motor , again. (IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) 3.2 used parts are $$$ very popular |
Bleyseng |
Nov 26 2005, 09:46 AM
Eddie won't care if it smokes some.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Steve |
Nov 26 2005, 10:17 AM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I agree. If your car is a track car you also want to make sure your car is maxed out in the class your competing in. I heard the 3.2 will put you in a class with some pretty killer semi tube frame cars. Otherwise I don't miss the hassle of the webers with the DME fuel injection. I can start my car without touching the gas pedal. It also has an altitude sensor that automatically adjusts the fuel injection when you drive in the mountains. |
Eddie914 |
Nov 26 2005, 10:57 AM
Unregistered |
Geoff is correct ...
I don't mind a little smoke out the tailpipe, but I do get annoyed with pieces of piston out the exhaust! Eddie |
Bleyseng |
Nov 26 2005, 11:27 AM
Eddie uses the car mostly for track days and there are no class rules other than don't hit somebody else passing! (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif)
J P Stein |
Nov 26 2005, 12:40 PM
Lookie here:
http://forums.pelicanparts.com/showthread....threadid=251729 Not cheep, but also not easy to find. |
Downunderman |
Nov 26 2005, 01:06 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
GE 80 cams.
propricer |
Nov 26 2005, 01:21 PM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
I 2nd the GE80 cams ... and 40's ... if you want low end out of a corner, you can't beat it. If you have a track with LONG straights, go with bigger displacement and / or bigger carbs. If its a mix of short and long and ax, go with smaller carbs and GE 80's.
nine14cats |
Nov 26 2005, 08:34 PM
Sorry guys...I'm 2nd on the list if the first guys deal falls through. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) Bill P. |
scotty b |
Nov 26 2005, 08:44 PM
Eddie and anyone else. I'm may be interested in your JUNK parts as I am building a display motor to put with my 36 H.P. VW and 356 display engines. All I really need are the external pieces (block,cylinders,heads, shit box carbs etc) No internal parts are necessary. P.M. me with any info. I am also interested in 356 parts too.
Lo-Fi Version | Time is now: 18th May 2024 - 10:04 PM |
