no power at, the injectors |
grasshopper |
Nov 27 2005, 08:07 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
ok, new post to get some more attention.... This is a 1.8 FI system. I am getting power to the points, but i cant tell where it ends.... it does NOT get to the injectors... also, is there a way to test a AFM... i think mine is shot (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) In tech tips 700.... or whatever the POS book from AA is (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) says to take off the cover, and move the meter off of the contact points, and i should here the dual relay click... well, i turn the switch on, and tryed it and nothing happened... but the dual relay click everytime i turn the switch on..... i dont think its supposed to click every time is it??? Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/locust.gif) im still learning (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Mueller |
Nov 27 2005, 09:11 PM
with the key on, AFM flap open, the dual relay should activate giving power to the fuel pump and the injectors.
did you take the cover off of the relay box? do both coils energize and pull the lever down to complete the circuit? Can you manually push the lever down on top of the coils to make a connection....these can rust preventing the correct operation go to this site: L-Jet trouble shooting guide and read it....please don't ask another question until you need help with the troubleshooting (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Very good site, I expect Britt to read this site as well before installing the L-Jet on his car..... |
bd1308 |
Nov 27 2005, 11:14 PM
got it mike....thanks
b |
Nov 27 2005, 11:37 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
thank you thank you thank you I have been looking for a good write up... Rich |
Lo-Fi Version | Time is now: 25th May 2024 - 03:18 AM |
