Converting: Lug Bolts to Lug Nuts |
dlo914 |
Nov 28 2005, 05:45 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
It's always been a PITA to reinstall the wheels onto the car w/ lug bolts so then im trying to find these double-ended studs to go w/ a set of lug nuts ive got. Does anyone know where i can find some 14mm double-ended studs? Thanks in advance.
Rockaria |
Nov 28 2005, 05:51 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
What length do you want? 14MM X ?? I have a set I don't need but they are not long enough by 2 or so threads for 911 Style fuch wheels.
dlo914 |
Nov 28 2005, 06:01 PM
14mm X 1.5" im gonna be using these on a set of rivieras. would you happen to have any pictures? |
Rockaria |
Nov 28 2005, 06:04 PM
When I get home tonight I will get all you need and email you on my bolts, I believe they are 1.5".
dlo914 |
Nov 28 2005, 06:07 PM
thanks Chris! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Dr. Roger |
Nov 28 2005, 07:29 PM
threaded rod and some red loctite work?
I dont know but i've thought about this solution before.... Rog |
Mueller |
Nov 28 2005, 07:56 PM
you scare me Roger (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) these are the only screw-in studs I'd trust...these are made by BBS Racing (you know, the company that makes BBS Racing wheels....) High strength screw-in studs |
Allan |
Nov 28 2005, 08:01 PM
You slay me Mike... Always worried about SAFETY... Thanks, sometime I see things posted that worry me...... |
Mueller |
Nov 28 2005, 08:04 PM
I know that Roger was kidding...or so I hope so......just wanted to get that out in case some newbie started looking at the floor stock in Home Depot and got some ideas.....it could happen....
Carlitos Way |
Nov 28 2005, 08:11 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
About $100 for "convenient" wheel changes... hmmmmm
dlo914 |
Nov 28 2005, 08:43 PM
tell me about it some "Bling" shop wanted to charge me $5/stud X 16 = $80 for convienent tire change.... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Nov 28 2005, 08:53 PM
for a convenient way to do it...have one per wheel Or carry one with you that is four inches long...thread it in and hang the wheel off of it... Attach the other three or four bolts..remove the rod and put in the last bolt.... Rich |
markb |
Nov 28 2005, 08:55 PM
There you go, making sense again. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
dlo914 |
Nov 28 2005, 09:01 PM
be a bitch if you misplace the rod during a flat tire situation... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Nov 28 2005, 09:09 PM
you might just have to remember how to balance the wheel on your feet like you already do now.....
Rich |
dlo914 |
Nov 28 2005, 09:11 PM
or thigh (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
Rockaria |
Nov 28 2005, 09:20 PM
Okay I gots the info. I got these from some toothless guy at the Flee market. He was a' wittlin them from a larger led pile made from used bullets! I think they are safe enough (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif)
For real: I got them from WheelComponents.com, not quite 80 bucks but when I got them I had little to no info to go on. I since noticed I needed longer ones. As per the REAL reason I have these extra. I have the 14mmX1.75 on my fronts now and they have worked great for years. 14mm X1.5"X14MM - 12 new ones and 9 used ones in perfect condition, just a bit dirty. go to this site for pics #2736-2742 http://www.rockaria.com/914parts/ Attached image(s) |
Rockaria |
Nov 28 2005, 09:28 PM
I also have an extra set of 14mmX1.75X1/2" studs I got just in case I could not find 14mm acorns, I could have used american 1/2" acorns instead. Didn't need them since I found the super light 14mm alloy acorns. I think they are really designed for different style rims that have a smaller hole for the bolt. Probly not the best idea with a rim with a 14mm hole.
Same site pictures #2743-#2746 Attached image(s) |
GaroldShaffer |
Nov 28 2005, 10:20 PM
Just go to your local VW dealer and ask for a tommy bar part number 893 012 223 works great for the 914. Just screw it in and hang the wheel while you install the other lug bolts.
Rotary'14 |
Nov 28 2005, 10:38 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
I remembered seeing those somewhere but I didn't know what they were called. Yeah Dlo, use those things. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) -Rob |
Lo-Fi Version | Time is now: 19th May 2024 - 06:25 AM |
