Fuel pump wireing, routing |
toon1 |
Nov 29 2005, 11:39 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I am now trying to chase down the wires to relocate the fuel pump. It is a black with red stripe and a brown @ the fuel pump connector. I found a black and red wire @ the connector on the relay board in the motor compartment.
Does the wire go into the car at that point? Can I ground the - side to the body or do I need to locate the brown wire also? Is it possible to check if everything works(relay board etc.) without the motor in the car? |
Lo-Fi Version | Time is now: 18th May 2024 - 12:50 PM |
