Zenith rebuild, which screw does what? |
thesey914 |
Dec 3 2005, 04:14 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Can anyone point me in the right direction for some base settings for my zeniths?
Which screw does what...idle, mixture, idle correction etc..also there is a screw that affects vaccum any settings for this? |
thesey914 |
Dec 3 2005, 04:15 PM
forgot diagram..
thesey914 |
twice
thesey914 |
Dec 4 2005, 03:41 AM
I have found some base settings on Pelican...
these are for PMOs though.. Initial adjustments (PMO) are as follows: Idle air correction: 1/8 turn out* idle screws: ½ turn in after touching throttle arm on each carb idle mixture screws: 2 turns out What i need to know is which screw is which... (guessing) the small screw which I've marked as idle balances the airflow at idle the larger screw (with knurled head and spring) adjusts the amount of fuel at idle. Someone must have done this before... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
effutuo101 |
Aug 13 2008, 11:45 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
resurecting this thread. Does anybody have a exploded diagram for the zenith carbs? I have spent about an hour looking for one. Thanks!
jasons |
Aug 14 2008, 12:18 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I put this in my bookmarks a long time ago, does it help?
http://www.gary.suggate.dsl.pipex.com/new_site/zenith.htm |
thesey914 |
Aug 14 2008, 03:30 AM
Yes I know Gary (fellow Brit) -I managed to get hold of a copy of the Zenith manual and after a bit of fannying -they're running at least as well as any other carb would
effutuo101 |
Aug 14 2008, 10:37 AM
Yes it does! Thank you for the post and the blow by blow of disassembly.
Lo-Fi Version | Time is now: 29th May 2024 - 03:19 AM |
