I have found some base settings on Pelican...
these are for PMOs though..
Initial adjustments (PMO) are as follows:
Idle air correction: 1/8 turn out*
idle screws: ½ turn in after touching throttle arm on each carb
idle mixture screws: 2 turns out
What i need to know is which screw is which...
(guessing) the small screw which I've marked as idle balances the airflow at idle
the larger screw (with knurled head and spring) adjusts the amount of fuel at idle.
Someone must have done this before...
