| Aaron Cox |
Dec 5 2005, 01:11 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
Billsteins with 5 notches.... 5" coleman collars......
???? most said 10" on This thread.... but a few use 8" will they work? can the 5" perch sit high enough on the Bilstein to have useful adjustment? i have a line on afco coil springs.....8" (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
| sj914 |
Dec 5 2005, 01:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
I got 8"s right now and it works. It'll get you about 4" clearance on the bumpstops on 22" tires. Go about an inch from the bottom of the collar and you'll be about right at the bump stops.
These are on koni sports though. |
| sj914 |
Dec 5 2005, 01:17 PM
Found a good place for qa1 coils. I think the site is cheperformance.com
| Aaron Cox |
Dec 5 2005, 01:19 PM
i think bilsteins' adjustment notches are lower than on a koni.... anyonw have a side by side comparison of koni vs bill? |
| Aaron Cox |
Dec 5 2005, 01:20 PM
about the same as jegs on QA1..... |
| BIGKAT_83 |
Dec 5 2005, 01:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,800 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States
How far can you compress a 8" spring before it coil binds?
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Bob (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
| Aaron Cox |
Dec 5 2005, 01:36 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)? im asking if, the threaded perch (5") will sit HIGH enuff, on a bilstein shock, to facilitate an 8" spring? |
| Aaron Cox |
Dec 5 2005, 01:40 PM
soo... i have these
(IMG:http://www.pelicanparts.com/catalog/images/new_images2/bilstein_shock_kit_914.JPG) and my perches (IMG:http://www.914world.com/bbs2/uploads/blog-1127533450.jpg) have the seating notch about .5" from the bottom.... so, if these were to sit on the top notch of the bilstein strut.... they would be ok with an 8" spring? |
| Aaron Cox |
Dec 5 2005, 01:47 PM
WAG they will work......
making purchase...... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
| sj914 |
Dec 5 2005, 02:07 PM
If it's at all useful(yeah I know they're not bilsteins). Here's some pics of it as low as it will go while just touching the bumpstops. The collars are about 6.5" from the bottom of the shock mounts.
Lo-Fi Version | Time is now: 20th April 2026 - 12:34 PM |
