915 Limited Slip in a 914/901 transaxle? |
Eddie914 |
Dec 6 2005, 07:16 PM
Unregistered |
I have found a 915 transaxle with Limited Slip.
Can the 915 Limited Slip differential be used in 914/901 Transaxle? I believe I will have to use the six bolt output flanges. Will 944 axles need to be used? Will they work with the redrilled 914/4 hubs currently on the ' 71 914/4 six cylinder conversion? Thanks Eddie |
wertygrog |
Dec 6 2005, 07:32 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif)
I read somewhere that limited slip diffs was an option on 914's........am I mistaken? Brent carry on! |
jim912928 |
Dec 6 2005, 07:34 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I say get a wevo and use the 915!
TimT |
Dec 6 2005, 07:58 PM
There is more than one flavor of 915 diff.. early diffs work with 901/914 boxes with no mods.. later ones require different flanges etc
Eddie914 |
Dec 6 2005, 08:20 PM
Unregistered |
This is a later version I believe ... 1986.
It might not be worth the effort. What is it worth? Thanks Eddie |
davep |
Dec 6 2005, 10:18 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Yes, there were available, but were pretty rare. Factory transmissions with LSD have HB serial numbers. |
wertygrog |
Dec 7 2005, 09:24 AM
where is the serial # on the tranny?
just curious. thanks, brent |
propricer |
Dec 7 2005, 09:38 AM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
Model number is on the underside right at the stub out ... I believe (?) the serial number is next to it but not sure.
brant |
Dec 7 2005, 10:05 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Eddie, is it a super cheap price?
because you may have to pay to have a stock Limited Slip rebuilt after you get it out... by the time you pay for the rebuild, will it be any cheaper than buying a brand new one from guard? plus the stock units only work on acceleration I believe where as the guard units work on accell and decell oh... installation costs are going to be the same on new versus used too. brant |
KenH |
Dec 7 2005, 10:42 AM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
The 915 & 901 basic LSD are the same and will interchange. The only thing that has to match are the axle stub flanges. Early ones had a "course spline" 18 splines I think, and the later ones had a "fine spline" 43 ??.
Guard Transmissions can supply either flange so the LSD can be converted to the proper Spine. 915 LSD are ZF or clutch type and can be set for 40% or 80% slip and are always engaged. Installation is not just bolt-and-go. Your Ring gear has to be fitted to the LSD and the "backlass" and "preload" of the differential have to be set. Ken |
KenH |
Dec 7 2005, 10:45 AM
Forget - no other modifications have to be made. With the proper Splines it will work with 914 axles.
Ken |
propricer |
Dec 7 2005, 10:53 AM
Ken ... clarification, please.
Are you saying that ANY 915 LSD will work in the 901 observing the spline issue as well as standard preload and backlash .. or just the early ones ??? Best ... Ed ( in Morgan Hill ) |
bondo |
Dec 7 2005, 11:04 AM
If this comes up for sale I might be interested, as I am using 911 style 6 bolt CVs anyways. Beware though, I'm a CSOB. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I have lots of 901 trans parts to trade though.
Aaron Cox |
Dec 7 2005, 11:07 AM
coarse or fine spline stub axles? EDIT - ok...u planned on using adapters |
KenH |
Dec 7 2005, 11:22 AM
The basic 901 - 915 ZF unit is the same, friction plates, spider gears, etc. The only differences are the output splines. I am not sure but I think the 930 ZF is the same also.
Ken |
xitspd |
Dec 7 2005, 11:26 AM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) My mechanic put a 915 limited slip into a 901. I raced the car in the Ensenada Grand Prix. Call Steve Aven at Steve's in Orange. It was a little bit of work, but well worth the effort.
brant |
Dec 7 2005, 12:26 PM
am I correct though in understanding that ZF built units do not have the ramp feature where they provide a percent of lock up during off throttle braking/deceleration? I know the guard unit does provide a chosen amount of lock up during off throttle. and I know you can select what rates you want for accel and decel, such as 80% - 50% but the factory units are not as tuneable. -do they free wheel during decel? -or do they just provide the same percentage during decel? brant |
Eddie914 |
Dec 7 2005, 12:48 PM
Unregistered |
Aaron,
What setup are you using to adapt the six bolt 911 type CV joints? Can they be installed on 914/4 axles? (inner spline count the same? It is rumorred that 944 axles are the correct length and bolt count ... Thanks Eddie |
Aaron Cox |
Dec 7 2005, 12:50 PM
944 setup. not 911 cv;s (IMG:http://www.914world.com/bbs2/uploads/blog-1128554912.jpg) 944 early cv's fit right onto 914/4 shafts.... |
KenH |
Dec 7 2005, 03:49 PM
The ZF is a friction disk unit. The amout of slip is the same for accel or decel.
Gaurd makes both types of LSDs, Torque Bias & ZF type, which sometimes confuses the discussion. Ken |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:43 PM |
