Noob shifter question 901 to 915, Can you use a 915 shifter on a 901 tran |
mrdezyne |
Dec 6 2005, 07:16 PM
Now on larger rolling jack stands! Group: Members Posts: 468 Joined: 31-July 05 From: Tulsa, OK Member No.: 4,510 |
Is it possible to use a 915 shifter on a 901 transaxle?
TimT |
Dec 6 2005, 07:33 PM
Yes, you have to mod the guts though.
Did it years ago.... trying to remember |
Dec 6 2005, 08:56 PM
Resident German Group: Admin Posts: 41,634 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
if you got some spare $$$, get a RennShift instead ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
GeorgeRud |
Dec 6 2005, 08:59 PM
You do have to modify the shifter, but Porsche had a 901 style shifter in the 1972 911s with a 915 transmission, so it is definately possible. Don't know if it would be a worthwhile project though.
mrdezyne |
Dec 6 2005, 09:03 PM
Well, this is sort of why I was asking... In the Mid-America catalog they list a gate shift kit for the 915. But then it also goes on to say "Upgrade your 901 gearbox to use a 915 shifter." Its item 411-098. I don't see it on the web site but its in the catalog. Nice price too!!!
I'm sure the RennShift is a great piece as I have read everyones reviews and they all have great things to say about it, but the $$$$ is the problem right now..... |
mrdezyne |
Dec 7 2005, 11:56 AM
Anyone seen this thing and have an opinion? For the price I might consider being a guinea pig and try it out. However if someone already has it and can give me the low down..... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
Once again, its only in the catalog and not on the web site..... Surely its been around for a while.... |
sanman |
Mar 14 2006, 04:03 PM
Leaving California Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None |
saw the same kit
bump |
mrdezyne |
Mar 14 2006, 04:58 PM
Its no longer available, even though it was printed in the last catalog.... Mute subject now....
Aaron Cox |
Mar 14 2006, 08:17 PM
a 915 is -
1 3 5 2 4 R if the 915 has a reverse lockout or a gated spring..... flip it around 180 degress.... R 4 2 5 3 1 and guess what! your lockout is now a 901 reverse gear (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) imagine that.... so... speculating here... i believe a 915 rennshift is identical (except shift rod attachment) but just the body is flipped 180 (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
JWest |
Mar 14 2006, 10:04 PM
First, you need to obtain a late 915 shifter (911 guys are not known for giving parts away dirt cheap), and to do it right, you need to cut the 915 shift housing and reweld 180 degrees around to get the lockout in the right place (how are your aluminum welding skills?). Most people want a short shift (my data point is that I sold about 1% shifters at stock throw when I offered them that way). Then add the gate shift. You are probably beyond the price of a RennShift now, and you still have the crappy factory lateral pivot in the 915 shifter.
Save up your money and get the unit designed to solve all the problems once and correctly. I will admit I am a little biased. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Do you have a side-shift? Forget all that above - you can't use the 915 shifter because even if you did weld together the proper linkage attachment to the shifter shaft, there is no way to access the adjustment bolt because of the size of the shifter housing. |
Joseph Mills |
Mar 14 2006, 10:44 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
mrdezyne -
check your mailbox - I pm'd you. .. |
Lo-Fi Version | Time is now: 13th May 2024 - 07:37 AM |
