Help with seatbelt options, 1970 914-6 conversion... |
boxsterfan |
Aug 20 2003, 09:41 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
I am working on my 1970 914-6 conversion. (Actually started some tear-down today as I play the "find the rust" game).
So, converting to later 914 retractable seat belts is a no-go I am told. (?) Requires way too much modification? What 4 or 5-point harness options do I have? Got pics? How was the install? How does it "look"? Car is intended to be street/show. |
Aug 20 2003, 11:54 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(boxsterfan @ Aug 20 2003, 08:41 PM) So, converting to later 914 retractable seat belts is a no-go I am told. (?) Requires way too much modification? yepp, late style retracteables would require cutting out and rewelding the recess and mounts on the back firewall from a late model car. not an option IMHO. get a good 5 point harness and you'll be happy. if that is not street-legal where you are, you can still keep the stock belt for driving on public roads ... Andy |
EdwardBlume |
Aug 20 2003, 11:58 PM
I use a 5 point that I drilled holes for through the firewall. You might consider a harness bar (if it works) to avoid drilling holes.
Red-Beard |
Aug 21 2003, 07:19 AM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
One of the aftermarket companies makes a retractable that you can use on the Early car. I've forgotten which one. There were some post on Pelican in the past on this. I'll search around.
If you do find something, I may be interested in the original seat belt adjustment covers. James |
boxsterfan |
Aug 21 2003, 09:32 AM
Thanks all. Red-Beard, please let me know if you find the aftermarket retractable seat belts.
If I find a replacement solution, the originals are yours. boxsterfan |
JWest |
Aug 21 2003, 09:38 AM
airkewl |
Aug 23 2003, 09:28 PM
Newbie Group: Members Posts: 45 Joined: 9-January 03 From: Seattle (Kirkland) Member No.: 120 |
I used the kit
KT106 SEAT BELT KIT, '70-'72 914 & 914/6, LEFT OR RIGHT from the PEPARTS site above on my stock 70 914-6. I hated the stock ones because they were so restrictive. The retractable ones were a true bolt in, and they work great. Tony |
airkewl |
Aug 23 2003, 09:31 PM
I should have added that the retractor mechanism is all enclosed in the unit which bolts up at the top bolt in the B pillar (behind your head). Pretty tidy.
Tony |
seanery |
Aug 23 2003, 09:33 PM
got pics?
GaroldShaffer |
Aug 23 2003, 09:41 PM
You bought another 914? Group: Benefactors Posts: 7,621 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Tony,
I don't care for the belts in my 70. I like the idea of these belts. How long did it take you to install the new belts? -Garold |
MarkV |
Aug 23 2003, 10:25 PM
I bought some new retractors from Peparts & they quit working just like the originals. They worked great for a couple of years and then the retractors got lazy. It is nice to have new belt webbing though. At the time I bought mine they were also selling new receivers.
Red-Beard |
Aug 24 2003, 04:52 AM
Wow! Kinda pricy. $300 for both sides.
James |
Mountain914 |
Aug 24 2003, 03:14 PM
Too much time in thin air! Group: Members Posts: 367 Joined: 22-May 03 From: Conifer, CO Member No.: 725 Region Association: Rocky Mountains |
If you car is Street/Show - you should go with the aftermarket retractibles, or at most a 4 point harness.
Harnesses can be cam-lock or hook-and-latch. Either way harnesses are a bit much for everyday street driving and passengers always find it a learning experience hooking up. Most people don't even use the 5th point (between the legs) unless they are racing (which you didn't mention you would do). Also - legality questions can come into play with certain harnesses *if* someone wants to make an issue out of it. I recommend for primarily street use go with the regular belts - retractibles being most desirable and comforatible and convenient for all. My experience - I use a 4 point and since I'm usually the only one in my car it's not too much an issue for me. I have never been approached about legality but have read it on the forums. Mine is a hook-and-latch and I can get harnessed in in about 5 or 6 seconds, and out in 2. Cam-Locks take much less time. This all assumes no adjustements need to be made. Either way - you are looking at modifications if you aren't doing the stock setup. I have seen a VW rabbit retractible installed into a 914 and it looked like no mods, haven't studied the other retractible solution, and know for a fact you have to add one to three more connection points if you do a 4 or 5 point harness. But harnesses look cool !! |
Joe Bob |
Aug 24 2003, 05:04 PM
www.peparts.com great stuff, total asshole owns it. DON'T TALK to Lucas, anyone else who answers the phone is OK.....
My 70 had a harness bar.....fabbed a mount onto that. |
airkewl |
Aug 25 2003, 11:59 AM
Installation on the PEPARTS stuff probably toook about an hour. It is literally 4 bolts: one each at the top at the B pillar which replaces that anchor with the new retractor, and then there is a new receiver on each side which is a straight swap at the center tunnel. Piece of cake.
Tony |
si2t3m |
Aug 25 2003, 12:07 PM
914 addict Group: Members Posts: 346 Joined: 9-January 03 From: Qc, Canada Member No.: 119 |
I kinda like the non retractable seatbelts in my 70 914...
I can get them real tight on me for DE's or autocrossing. I know, next step will be a harness & harnessbar. If i could only figure out a way to install a harness bar while keeping the early backpad i'd be happy. Marc-André |
Lo-Fi Version | Time is now: 10th May 2024 - 07:28 AM |
