PPI In Huntington Beach, CA? |
kconway |
Dec 7 2005, 10:27 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Going to take a look at a 73 1.7 tomorrow - http://adcache.collectorcartraderonline.co.../1/81866941.htm
Anyone in or around HB seen this car or know the guy or perhaps interested in doing a PPI? Says he was putting it back together but has given up. Still has the FI, light rust, but needs interior work. Engine was worked over with the easy stuff but hasn't sorted electrical, thus it is not currently running. Whaddya think? |
lagunero |
Dec 7 2005, 10:54 PM
Donkey Member Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
Hopefully the HBer's will chime in. If no one has by this weekend, I can go down there.
Series9 |
Dec 7 2005, 10:59 PM
?Donde esta Jose Sharp?
skline |
Dec 7 2005, 11:00 PM
I am in Costa Mesa but am in HB all the time and if you want someone to go with you to look at it, I may be able to. I have a job in Long Beach around 9 AM and should be done sometime between noon and 2 in the afternoon. Send me a PM and I will send you my number.
lagunero |
Dec 7 2005, 11:03 PM
con el Venadito Cazadores |
Series9 |
Dec 7 2005, 11:12 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
JB 914 |
Dec 7 2005, 11:36 PM
Daddy! Finish my car NOW!!! Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 |
(IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) |
JB 914 |
Dec 8 2005, 01:05 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) I had two with light rust. I would bring a screwdriver to the PPI. check the floorpans along the seams with the longs and in the rear corners of the floor pan. as always check the hell hole area too. check the door gaps to see if it "sags" from rusty longs. below is a picture of the "light rust" i found on my California car. you could put your fist thru that square area. Before i started to really dig it looked like surface rust. once i started to poke with a screw drive and clean it up it all just started to flake away. i had to cut out that plus about 6 inches forward to get to solid floor board. Same on the other side. I think rust is like an iceberg. what you see is only on the surface. It's not that it cant be fixed. It's just time consuming if you do it yourself and $$$$ if you get someone else to do it. BTW, if you do get it and need to fix the rust, POR-15 is the bomb. Marine clean, Metal Ready and POR-15 paint. a little goes a long way. Attached image(s) |
JoeSharp |
Dec 8 2005, 06:16 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Well I just went and looked at the car.
It has some rust and it is a porject car but for $950 you should come down and look at the car before Thomas finds it and cuts it up. :PERMAGRIN: Joe |
Aaron Cox |
Dec 8 2005, 06:47 PM
:sawzall demon: (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 10:21 AM |
