quick question: installing rear defogger, terminals on window go IN to the cabin? |
Aaron Cox |
Dec 9 2005, 03:37 PM
pretty sure.... terminals on window go INSIDE the car right?
AA |
bondo |
Dec 9 2005, 03:42 PM
Put them on the side that fogs up. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
balljoint |
Dec 9 2005, 03:46 PM
Right. But that rear window is a defroster, not a defogger. Defogging is done with fresh air and heat. Defrosting is done with the elements on the rear window. ie heat up the window and melt off ice forming outside. (I can't see how that would be a problem in such a small cabin unless you had no heat) |
Aaron Cox |
Dec 9 2005, 04:01 PM
wierd... terminals go on the inside, where they ,meet the harness??
(ive yet to install the harness.... |
sk8kat1 |
Dec 9 2005, 04:06 PM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
they are on mine
mike |
Rand |
Dec 9 2005, 04:07 PM
Yup... What are you going to hook them up to? Do you have the circuit already or do you need to run the wires? At any rate, they should be in the cabin.
Aaron Cox |
coool thank you.
AA |
Aaron Cox |
Dec 9 2005, 04:08 PM
rand - thanks again for the switch!
you may have also done this drawing? i have a harness from grasshopper... (IMG:http://www.914world.com/bbs2/uploads/blog-1...-1131153664.jpg) |
Rand |
Dec 9 2005, 04:09 PM
Oops... after I posted I saw your harness Q.
Aaron Cox |
Rand |
Dec 9 2005, 04:12 PM
Kind of ironic since the rear window is way more likely to fog up than get frost on it. |
Rand |
Dec 9 2005, 04:22 PM
Cool! I don't recognize the drawing. I remember from my car that the wires went through the center tunnel, then one up each side of the firewall behind the backpad to the tabs on the glass. Royce can probably nail down the details. |
Lo-Fi Version | Time is now: 28th May 2024 - 03:49 AM |
