Aaron Cox
Dec 9 2005, 03:37 PM
pretty sure.... terminals on window go INSIDE the car right?
AA
bondo
Dec 9 2005, 03:42 PM
Put them on the side that fogs up.
balljoint
Dec 9 2005, 03:46 PM
QUOTE (Aaron Cox @ Dec 9 2005, 05:37 PM) |
AA |
Right.
But that rear window is a defroster, not a defogger.
Defogging is done with fresh air and heat. Defrosting is done with the elements on the rear window. ie heat up the window and melt off ice forming outside. (I can't see how that would be a problem in such a small cabin unless you had no heat)
Aaron Cox
Dec 9 2005, 04:01 PM
wierd... terminals go on the inside, where they ,meet the harness??
(ive yet to install the harness....
sk8kat1
Dec 9 2005, 04:06 PM
they are on mine
mike
Rand
Dec 9 2005, 04:07 PM
Yup... What are you going to hook them up to? Do you have the circuit already or do you need to run the wires? At any rate, they should be in the cabin.
Aaron Cox
coool thank you.
AA
Aaron Cox
Dec 9 2005, 04:08 PM
rand - thanks again for the switch!
you may have also done this drawing?
i have a harness from grasshopper...
Rand
Dec 9 2005, 04:09 PM
Oops... after I posted I saw your harness Q.
Aaron Cox
Rand
Dec 9 2005, 04:12 PM
QUOTE (balljoint @ Dec 9 2005, 01:46 PM) |
But that rear window is a defroster, not a defogger. Defogging is done with fresh air and heat. Defrosting is done with the elements on the rear window... |
Kind of ironic since the rear window is way more likely to fog up than get frost on it.
Rand
Dec 9 2005, 04:22 PM
QUOTE (Aaron Cox @ Dec 9 2005, 02:08 PM) |
rand - thanks again for the switch! you may have also done this drawing?
Cool!
I don't recognize the drawing. I remember from my car that the wires went through the center tunnel, then one up each side of the firewall behind the backpad to the tabs on the glass. Royce can probably nail down the details.
