Online source for electrical parts, Like connectors etc... |
ChrisReale |
Aug 21 2003, 03:06 PM
Mainly I am looking for the connectors that plug into the FI Trigger Points. They are small, and radio Shack doesn't have them. Is there an online place where I can search for these types of things?
tryan |
Aug 21 2003, 04:09 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
see if this is what you need.
Charles Deutsch |
Aug 21 2003, 04:25 PM
Unregistered |
Aug 21 2003, 05:13 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Ask Bowlsby nicely. He has them. I was able to find parts that were "close" at a local Metric and Electrical supply house, Global Metrics in Belmont CA. I was also able to get them from a Beck-Arnley dealer--B-A supplies parts to a lot of auto parts stores.
But frankly, Chris, if the harness is old enough that the connectors are falling off, you really owe it to yourself to just get a rebuilt one (yeah, 99% new is "rebuilt") so you can know it's all in good shape. --DD |
ChrisReale |
Aug 21 2003, 05:42 PM
Yea, I do need a new one, but it is not that bad yet. Its not that it is falling apart, just a few of the connectors need to be replaced (IMG:style_emoticons/default/laugh.gif)
Qarl |
Aug 21 2003, 07:43 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Damnit! I remember coming across some site (Besides Bowlsby's) that had fuel injection boots and all kinds of grommets and fuel injection pieces.
I thought I book marked it, but now I can't find it! If anyone else does, post the link here. Karl |
tryan |
Aug 21 2003, 07:51 PM
i'll look for triggers.
Attached thumbnail(s) |
JeffBowlsby |
Aug 21 2003, 08:07 PM
914 Wiring Harnesses Group: Members Posts: 8,502 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
If all you need is a couple wire terminals...I do simple repairs too...
I clean and bench test the entire harness, replace boots and any other missing parts and make it good as new. |
DNHunt |
Aug 21 2003, 08:26 PM
Chris, Check wrecked Vanagons. Many of the connectors are the same. they are not new but are better. Be prepared to solder.
Dave |
JeffBowlsby |
Aug 21 2003, 08:33 PM
Dave, Vanagons are L-jet, and the 73 714s are D-Jet as you well know. Two different connectivity systems that are not easily interchangeable.
The L-jet wire terminals do not fit into the 3 pole trigger point (or any of the ) D-Jet housings, but the L-jet housings can be made to fit onto the D-Jet FI components. Its just that the L-Jet parts need modification to fit and then the connection wont be encased by a rubber boot as teh D-Jet is, so the connection will get contaminated with moisture, dirt, and all the other stuff found in open engine compartments. |
tryan |
Aug 21 2003, 08:36 PM
mercedes, volvo, type III vw's and others all used the trigger type bosch injection and should have the same plug. i would let jeff check out the whole harness.
Lo-Fi Version | Time is now: 13th May 2024 - 12:51 PM |
