4 Pages V « < 2 3 4
> TYPE lV NIKASIL CYLINDERS, From 98mm to 104mm
gothspeed
post May 5 2010, 07:13 PM
Post #61
QUOTE(ChrisNPDrider @ May 5 2010, 05:55 PM) *
If you can afford them, contact Len and get some Nikkies from LN Engineering.
They are the bomb. Reliable builds reported here with all sizes in a TIV.
No direct experience from me, I just read a lot. (IMG:style_emoticons/default/beerchug.gif)
They are cool (IMG:style_emoticons/default/smile.gif)!! But $3000-ish for pistons, cylinders and head studs is a little steep IMO. Then I would be forced to spend more money on the rest of the motor as it would have to match the cylinders (IMG:style_emoticons/default/ohmy.gif).
Randal
post May 15 2010, 08:27 AM
Post #62
I'm sure others here have mentioned the importance of buying a product that is proven and works. In the case of a motor, especially a motor that isn't going to be stock, you want the absolute best parts. I mean why put something on your built motor that has any possibility of failing. Want to build it twice?
As to Charles, he's an absolute great vendor. He tells you everything you need to know, is always there to work with you, totally honest and basically a stellar guy.
Everything I have purchased from Charles has worked as he outlined and I've never had even one simple glitch with any of the product he sells.
Just a great all around, no drama, guy who has your interest as a first priority.
craig downs
post May 15 2010, 09:29 PM
Post #63
One of the reasons Charles has mentioned before why they are expensive is the nikasil plating he uses for his cylinders. It is the best he has found and thats why there is a life time guaranty on the plating not to flake. If you want the best you got to pay the price for admission.
gothspeed
post May 16 2010, 01:50 AM
Post #64
Well that settles it. Since the absolute 'best' cylinders for my 914 is not that important to me. Standard cast iron cylinders should do the trick (IMG:style_emoticons/default/smile.gif).
craig downs
post May 16 2010, 01:21 PM
Post #65
Good cast iron cylinders are fine up to 96mm
ME733
post May 17 2010, 11:47 AM
Post #66
..............Cast Iron Cylinders, are available up to 105 mm bores....And unless you expect to have an engine, producing over 50 H.P. per cylinder, Thats 200 actual H.P. total........then cast iron cylinders will work just fine....you will need an external oil cooler, as the H.P increases over about 125....The drama, expense, additional specalized parts and assembly techniques, are just not worth all the extra effort for a street car producing less than 150-175 actual H.P....In my opinion.
4 Pages V « < 2 3 4
- Lo-Fi Version Time is now: 3rd October 2026 - 05:47 PM
