Painting of POR-15, Will the body shop kill you... |
boxsterfan |
Aug 21 2003, 03:50 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Is it possible to paint over POR-15 and still have a great looking paint job? Or do the body/paint guys just hate this stuff?
I would suppose that you could paint over POR-15 on the inside of the car (under carpets for example) because no one normally worries about a great shining paint job there. (IMG:style_emoticons/default/beer.gif) boxsterfan |
tryan |
Aug 21 2003, 04:00 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
karl thinned some down and sprayed it. in the floriduh humidity no less.
it is not uv stable, so it must be topcoated or kept out of the sunlight. |
Chris H. |
Aug 21 2003, 04:03 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Not sure I have a recommendation on topside, but for the underside/floorpans/trunkls/etc, they make a primer/topcoat that helps get regular paint to stick to it. Otherwise it's too slick and paint will not adhere.
ArtechnikA |
Aug 21 2003, 06:04 PM
QUOTE(boxsterfan @ Aug 21 2003, 01:50 PM) Is it possible to paint over POR-15 and still have a great looking paint job? Or do the body/paint guys just hate this stuff? they make a topcoat primer that's supposed to allow any paint to stick. but (per the instructions i read just last night) you can also hit it with a dust coat of 'regular' paint while the POR is still tacky and that will form a layer new paint can adhere to. |
Lo-Fi Version | Time is now: 14th May 2024 - 01:06 AM |
