Ride Height?, and autocross alignment settings? |
billd |
Dec 15 2005, 01:49 PM
Member Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 |
What do people recommend for ride height and alignment settings for a 2.0L being used primarily for autocross. The rear ride height is constrained by the springs with the perch on the lowest "slot" in the Koni shock. For front height I was thinking of 125mm from the center of the torsion bar to the center of the spindle. This is 35mm lower than the stock 90mm. For camber I was thinking of -2 degrees in front and -2.5 degrees in back.
I've finally got the suspension put back together with 180# springs and Koni Sports in the back, 21mm torsion bars, Koni Sports, poly bushings, and turbo tie rods in front. Now I just need to set the alignment and get a decent set of tires (Faken 615s) on it. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:57 PM |
