Dave Bell |
Member ![]() ![]() Group: Members Posts: 234 Joined: 27-November 03 From: Santa Clarita, CA Member No.: 1,398 Region Association: None ![]() |
Broke down an engine to get ready to build something..
Thought you would enjoy pictures of a clean case. - Dave Attached thumbnail(s) ![]() |
Dave Bell |
asdf
Dave Bell |
asd
Dave Bell |
asd
Dave Bell |
Nother one
Dave Bell |
and another
michelko |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/yikes.gif) Holy (IMG:http://www.914world.com/bbs2/html/emoticons/post-2-1117899824.gif)
What did you use to clean the case. Looks like a jewel! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Plug the holes and use it for a Jello mold. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Leo Imperial |
Do you have to use so many cuss words? ![]() ![]() ![]() Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None ![]() |
Great shots and an awsome job (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
The wide-angle shots are the BOMB (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) |
lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
how importaint is it to clean up like that? i'll be rebuilding soon, thanks.
root |
Two Wheeled Type4 Completed! ![]() ![]() ![]() Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None ![]() |
I know how you did it! Acetone and a tootbrush, RIGHT? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
lets see the other side....
b |
Dave Bell |
Well I had a little help...
Your local machiine shop will have a power washer for things like this..... I took the case halves to them and they came back with only residual bits of crap left on them... mostly gasket and sealant left over on some harder to reach surfaces. Following two shots show what the other side looks like as I recieved it back from the machine shop. Then I clean off the residual junk with scotch brite, small screw driver, small wire wheel on die grinder + degreaser or Lacquer Thinner. So I still have the residual clean up to do on the other half. Cost for the wash... not sure exactly since I had them pull the gears off of the old crank at the same time. Total cost for wash and gear pull was $40. My friiend Bill Greenway tells me he has gotten the wash itself done for as little as $15 to $20. |
Dave Bell |
asd
Dave Bell |
asd
root |
Dave,
Great job! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) Let us see the heads when there pretty too! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
bd1308 |
is that outlet you have that GFCI tester on working okay?
b |
TJB/914 |
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,336 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest ![]() ![]() |
Dave,
That is so beautiful. You could make that 1st picture into a wall poster?? Hopefully Seanery is listening. BTW, Hope your tooth problem is ok. When I did my restoration a number of years ago there was a guy in Indianapolis, IN by the name of Roger Reynolds (Ottowerks) who had a cleaning process. All the 356 guys used him. I sent my engine, fan housing, trans & a few other parts to be cleaned. When they came back they looked like they just came out of the casting mold. Very reasonable & worth the price. I wonder if Mr. Reynolds is still in business?? (He also had a real 1972 914-6 in pcs.) Hey, Seanery do you know him from Indy??? Tpm Here is a pic to show. Attached thumbnail(s) ![]() |
Dave Bell |
Heads I bead blasted myself... I have a Harbor Freight Blast cabinet... it really cleans things up.
Dave Bell |
asd
Lo-Fi Version | Time is now: 10th June 2024 - 06:47 AM |
