Carpet Glue, what to use?? |
tod914 |
Aug 23 2003, 06:12 AM
Any suggestions on a good carpet glue? I tried the 3m general adhesive on some loose vinal. It didnt hold up to well. So I would assume it would work poorly on carpet.
Thanks |
TheCabinetmaker |
Aug 23 2003, 06:27 AM
carpet glue or cove base adhesive from Home Depot or Lowes
Demick |
Aug 23 2003, 08:33 AM
I used the 3m super spray adhesive for my carpets and it worked great. Be sure to follow the instructions - spray on both surfaces, wait a few minutes, and then stick together. It works like contact cement.
Demick |
Jeffs9146 |
Aug 23 2003, 10:08 AM
jari-jodokus |
Aug 23 2003, 01:05 PM
Newbie Group: Members Posts: 6 Joined: 27-July 03 From: Apeldoorn The Netherlands Europe Member No.: 955 |
I did not glue my carpet! So it is easy to remove for inspection .....and moist and water can be seen before it gets to rust and the carpet can dry more easily.
But i must add : it rains a lot overhere! The carpet will soon take its shape , you could use 2-side-tape to get a proper attach. In my other car (Borgward Isabella '57) we put first liters (1/4 gallon) ML-tectyl/Wax on the floor then undercarpet soaked in it and then glued the actual carpet with 3M-spray-glue. Succes! |
tryan |
Aug 23 2003, 01:11 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
monkey snot...
3m makes an 0077 and a 0078. i think the 78 is stronger. |
Maine914 |
Aug 24 2003, 07:58 AM
Member Group: Members Posts: 99 Joined: 30-January 03 From: Maine Member No.: 215 |
I use velcro tape strips so I could pull the carpet up whenever I wanted for cleaning and inspection. Works fine.
Lo-Fi Version | Time is now: 11th May 2024 - 07:03 PM |
