tod914
Aug 23 2003, 06:12 AM
Any suggestions on a good carpet glue? I tried the 3m general adhesive on some loose vinal. It didnt hold up to well. So I would assume it would work poorly on carpet.
Thanks
TheCabinetmaker
Aug 23 2003, 06:27 AM
carpet glue or cove base adhesive from Home Depot or Lowes
Demick
Aug 23 2003, 08:33 AM
I used the 3m super spray adhesive for my carpets and it worked great. Be sure to follow the instructions - spray on both surfaces, wait a few minutes, and then stick together. It works like contact cement.
Demick
Jeffs9146
Aug 23 2003, 10:08 AM
3m worked great for me
Jeff
jari-jodokus
Aug 23 2003, 01:05 PM
I did not glue my carpet! So it is easy to remove for inspection .....and moist and water can be seen before it gets to rust and the carpet can dry more easily.
But i must add : it rains a lot overhere!
The carpet will soon take its shape , you could use 2-side-tape to get a proper attach.
In my other car (Borgward Isabella '57) we put first liters (1/4 gallon) ML-tectyl/Wax on the floor then undercarpet soaked in it and then glued the actual carpet with 3M-spray-glue.
Succes!
tryan
Aug 23 2003, 01:11 PM
monkey snot...
3m makes an 0077 and a 0078. i think the 78 is stronger.
Maine914
Aug 24 2003, 07:58 AM
I use velcro tape strips so I could pull the carpet up whenever I wanted for cleaning and inspection. Works fine.
