Front Sway Bar, How To?? |
19144jt |
Dec 19 2005, 03:18 PM
Member Group: Members Posts: 176 Joined: 19-September 05 From: Grass Valley, CA Member No.: 4,829 |
I have two parts cars with the stock front sway bars that go through the inner fender well on each side. My driver that I'm fixing up does not have a front sway bar. Can I put one from the parts car on my driver? What does it intail??
Thanks, John |
bryanc |
Dec 19 2005, 03:35 PM
Member Group: Members Posts: 321 Joined: 9-August 04 From: San Antonio, Tx Member No.: 2,495 Region Association: Southwest Region |
There is an article over at pelican parts describing the procedure.
Basically, you have to remove the gas tank, drill two 1" holes in the body, then mount the brackets. You will either need to swap a-arms with your parts cars or get the bolt on solution from weltmeister for the mounting tabs. The bolt on works ok, but welding them is stronger. |
double-a |
Dec 19 2005, 03:38 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
just did this a week ago! i put in an aftermarket 22mm bar, but installation process is basically the same no matter what bar you're putting in. pelican's guide is very helpful, and if you run into any trouble, there are many here who can help.
~a |
dlo914 |
Dec 19 2005, 03:39 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
here's the link to the article http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm |
dlo914 |
Dec 19 2005, 03:41 PM
and here's the article for the rear sway bar if you decide to install one: http://www.pelicanparts.com/techarticles/9...4_rear_sway.htm
rjames |
Dec 19 2005, 04:30 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Anybody ever heard of the brand 'Turn 6' swaybars? I found a set of NOS, both front and rear for $195. Wondering if it's worth it, or if I should look to spend a little more for an adjustable and just get the front one.
Trekkor |
Dec 19 2005, 05:51 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
orange914 |
Dec 19 2005, 08:51 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
im thinking about a front bar addition also, but is this going to worsen handling without the rear bar(oversteer/balance issue)? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Mueller |
Dec 19 2005, 09:00 PM
tons, and tons of 914 came from the factory with only a front bar.... a stock skinny front bar is better than no bar at all...period do not run a rear bar without a front bar, that is dangerous on our cars... front bar only = yes front and rear bar = yes rear bar only = no |
Trekkor |
Dec 19 2005, 09:09 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) with mueller.
I run both bars. It seems that most do not (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) KT |
jd74914 |
Dec 19 2005, 09:13 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
you have the bar to end all bars tho (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Trekkor |
Dec 19 2005, 09:18 PM
True... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 05:46 AM |
