Problems if I don't run the decel valve??? |
Mueller |
Feb 12 2003, 02:04 PM
Currently my D-jet 2.0 only has two of the three hoses hooked up on the Decel valve (two larger diameter that go to the plenum)...where does the third line go?
What are the ill effects of removing this all together to rule out vacuum leak sources while I fine tune the motor (don't worry Mike, I'll put it back (IMG:style_emoticons/default/smile.gif) ) |
Lo-Fi Version | Time is now: 19th May 2024 - 11:06 PM |
