HOW TO???, removal of carbon |
Dec 20 2005, 11:22 AM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
So,
on the heads and tops of pistons... How do you remove the carbon... the piston I am not as worried about... I would like something gentle to remove the carbon from the head.... What have you guys done... I have searched... Rich |
Joe Ricard |
Dec 20 2005, 11:35 AM
You can use something like a wood stick (or plastic) Then move to carb cleaner and scotch brite pads. Just don't gouge them with a screw driver.
with the heads off of course (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
qa1142 |
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
de-grease to get any oil out and then use brass brissle brush
blitZ |
Dec 20 2005, 11:57 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Soak it in some SeaFoam, most FLAPS have it. The marine industry has been using this stuff for years to decarbon outboards. Works great on cars.
Bleyseng |
Dec 20 2005, 01:31 PM
dlo914 |
Dec 20 2005, 02:07 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
If your car was running you could use this one product called "Sea Foam" at your local FLAPS... a friend used it and boy the exhaust was bellowing out black smoke from the carbon deposits in his cylinders. (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif)
dlo914 |
damn Blitz got to it first (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
toon1 |
Dec 20 2005, 03:08 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I used Sea foam in my 96 dodge 1500 tranny. The thing wouldn't shift from second to third. Added Sea foam and in about 15 of driving the tranny shifted perfectly. If all their products work that well you can't go wrong.
jhadler |
Dec 20 2005, 03:12 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
With a dissasembled motor, I found easy-off to work quite handilly. Just use in a well ventilated area. Easier I guess in the summer when things are warmer...
-Josh2 |
ClayPerrine |
Dec 20 2005, 03:19 PM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I found a very good carbon remover.....
Plain old water. All you do is get a gallon of water and a long piece of vacuum hose. Hook the vacuum hose to a vacuum port on the engine, run the engine about 2500 rpm, and put the other end of the vacuum hose in the jug of water. The water will turn to steam when it hits the combustion chambers. The steam loosens and removes most of the carbon. The car will try to misfire and will run bad while you are doing this, but if it tries to die, just pull the hose out of the water. You get to spew lots of steam out of the exhaust too. (Ever seen the pistons on a water cooled car after a blown head gasket? They are clean as a whistle.) |
Dr. Roger |
Dec 20 2005, 03:33 PM
wire wheel on the end of a drill.
then polish the same way so less carbon sticks to the combustin chambers. works like a charm. |
brer |
Dec 20 2005, 03:49 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
a lady i knew who raced 356's told me to pour water down the carbs of my S90. I told her to take a hike. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) At the time it sounded silly. now i'm wondering, wont dislodging carbon while running introduce lots of debris to the piston rings? |
Katmanken |
Dec 20 2005, 05:00 PM
I think American Motors used that as a tune up technique in the 60's. They are also outa business as a comapany.
That being said, I too have used water to clean the engine. On a beetle, it's easy.... Remove air cleaner, slowly dribble water into intake while revving engine. Done it many times. Haven't tried it on an injected engine yet... Ken |
Dec 20 2005, 05:23 PM
I appreciate the suggestion...and I learned a few things...
But alas, the engine is taken apart... I would like to clean the heads and pistons before I put it back together... I am not to worried about the pistons...if they get a little scratched...oh well... But the heads...specifically where the cylinder mating surface is...I dont want to scratch it, or deform it... I am looking for a chemical that will do the trick with a tooth brush, or a light brass wire brush... Rich |
jhadler |
Dec 20 2005, 05:28 PM
"Easy-Off"!
No really, what do you think it's made to do? Disolve carbon deposits.... Just make sure the parts are "warm" before you do it. NOT hot. Just room temperature. So bring 'em inside for the night before hitting 'em with the stuff. I cleaned two sets of heads and a set of pistons in a day with a few cans of the stuff. Make sure you've wiped off the parts as good as you can, and that they're at least room temperature. Then take 'em outside, spray 'em down, and let 'em sit a while. Then go at 'em with a nylon bristle brush. Wipe off, repeat as needed. It took me about three rounds to get 'em pretty clean. They won't be bead blaster clean, but they certainly weren't all cruded up with carbon though either... YMMV... -Josh2 |
Dec 20 2005, 05:31 PM
that is amazing stuff...
Someone needs to wrtie a book...101 things easy off can do.. I was told it takes off pinstriping without damaging the underlying paint... Yup, it worked...I have a can here from that project... I also heard Coke (classic formula) is a good cleaner... Rich |
Gint |
Dec 20 2005, 06:30 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
It's a little late now, but I can't believe no one said it...
Chopsticks! |
Lo-Fi Version | Time is now: 30th April 2024 - 02:47 PM |
