Transmission trouble? |
jwade |
Aug 23 2003, 07:34 PM
Member Group: Members Posts: 94 Joined: 23-February 03 From: Los Angeles, CA Member No.: 340 |
Hi all,
I was driving today when I heard a loud BANG from the rear of the car and my transmission stopped working. I could shift in all gears with or without the clutch depressed but it would not engage. For the last two days the car has shifted harder and I had to be sure I pushed the gear shift very far to the right to engage 4th and 5th. I suspected the shift linkage and checked the shift support but everything seemed to be OK except the shift lever shaft slides out about a half inch. Is this something that can be fixed with the tranny in the car (if that is the problem)? Or is it something that a novice should not attempt? Or could it be something I have not considered (of course it could!)? I hate having all this wonderful driving weather and being stuck in the hardtop. Any thoughts would be appreciated. thanks, john |
Jeffs9146 |
Aug 23 2003, 07:37 PM
And?????? Welcome to the board, do you have a transmision problem? I am sure someone here will point you in the right direction or just point at you!! (IMG:style_emoticons/default/aktion035.gif)
Jeff |
jwade |
Aug 23 2003, 07:46 PM
I know, don't hit enter before you type your message (IMG:style_emoticons/default/rolleyes.gif)
Jeffs9146 |
Aug 23 2003, 11:47 PM
QUOTE I could shift in all gears with or without the clutch depressed but it would not engage Well, just a guess but the pressure plate/throughout bearing?? What happens to the clutch when it is pressed? Any grinding when you try to push it into gear? Jeff |
jwade |
Aug 24 2003, 12:06 AM
There does not seen to be any difference whether you press in the clutch or not.
This is why I don't suspect a clutch problem. john |
Jeffs9146 |
Aug 24 2003, 12:11 AM
So, if you try to force the shifter into possisition will it grind or not go?
Jeff |
jwade |
Aug 24 2003, 12:12 AM
does not grind or anything
Jeffs9146 |
Aug 24 2003, 12:14 AM
Can you get someone to press the clutch while you watch the cable on the roller and the throughout arm move??
Jeff |
jwade |
Aug 24 2003, 12:27 AM
I can do that. Since I didn't suspect the clutch, I had someone shift through the
pattern to see if the linkage was working properly. I'll have to get them to depress the clutch to see if there is any reaction. john |
Jeffs9146 |
Aug 24 2003, 12:39 AM
That would be the first step. The clutch tube can break loose and the clutch wont engage but it usually causes a grinding. The cable could be broken but you would have the same/similar symptoms as the clutch tube. The pressure plate could fail and stop engaging. You would be lucky if you didn't hear any springs bouncing around in there but it could be! Syncros??? I don't know if they just fail like that? Someone else might know that?
Jeff |
Red-Beard |
Aug 24 2003, 08:50 AM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Doesn't sound like a clutch tube. Clutch tube breaking make the clutch not operate and you drag the clutch when trying to shift. It sounds to me that you are not getting any power to the tranny. Either the clutch disk is totally gone (Possible) or you may have a broken input shaft.
Other than hard shifting, did you notice a lot of noise in the tranny especially at higher RPMs, ie more noticable in 1st gear since you going slower? James |
jwade |
Aug 24 2003, 08:55 AM
I did notice some noise when in first gear, but not a lot. I replaced the clutch cable
within the last 4 months. So far, everyone seems to be focusing in the clutch so I guess I should take it somewhere to have it properly diagnosed. john |
Jeffs9146 |
Aug 24 2003, 12:43 PM
Drop it yourself and take a look! It is not very hard to do!
Jeff |
TheCabinetmaker |
Aug 24 2003, 01:14 PM
I had a similar problem years ago. Turned out to be a small pin that had slipped out of the shift forks and was laying in the bottom of the case. nO damage. Reinstalled it and everything was fine.
jwade |
Aug 24 2003, 05:59 PM
I took the shift fork out and that is not the problem.
Maybe the CV joint or axle? john |
redshift |
Aug 24 2003, 06:40 PM
If a CV comes off.... yeah, it won't go anywhere, and it will act just like you say.
I don't know what all error modes (lol) a CV throws off, I have only experienced the catastrophic type, maybe one's dead in the cage. M |
SPGofNM |
Aug 25 2003, 12:30 PM
Newbie Group: Members Posts: 5 Joined: 14-May 03 From: Albuquerque, NM Member No.: 698 |
Had a similar noise in mine did all the external checks then pulled the transmission and found the pinion head had broken off the shaft. Hope yours turns out to be something simple
Brad Roberts |
Aug 25 2003, 12:33 PM
WOW.
I have stripped teeth off of them.. but never broken one completely off. Welcome to the BBS ..and thanks for posting. B |
jwade |
Aug 30 2003, 04:55 PM
Probably the CV joint. When I turn the wheel the axle rotates up to the CV joint but the part attached to the transaxle doesn't move. My question now is, HOW DO I GET THE DAMN CASTLE NUT OFF? It doesn't budge and I don't want to break anything by using too long a lever.
john |
ArtechnikA |
Aug 30 2003, 06:22 PM
QUOTE(jwade @ Aug 30 2003, 02:55 PM) Probably the CV joint. When I turn the wheel the axle rotates up to the CV joint but the part attached to the transaxle doesn't move. My question now is, HOW DO I GET THE DAMN CASTLE NUT OFF? It doesn't budge and I don't want to break anything by using too long a lever. impact wrench if you've got one. long pipe lever otherwise. be careful. they're put on at 220 lbs-ft and seem to want to self-tighten and/or sieze in place. spray liberally with a good penetrating oil as far in advance as possible. have all 4 wheels on the ground if you're using the big lever method - and ideally for the impact method too. |
Lo-Fi Version | Time is now: 10th May 2024 - 06:46 AM |
