six oil tank, factory vs. vellios |
bhfast |
Feb 12 2003, 02:47 PM
live it loud, balls out Group: Members Posts: 83 Joined: 30-December 02 From: Chandler, AZ/Daytona Beach, FL Member No.: 48 Region Association: Southwest Region |
Factory: steel(can rust), lighter weight, internal baffle
Vellios: aluminum, heavier, about $100 cheaper Is there anything I'm missing here? Is one better than the other? What are you using? Brian |
Brad Roberts |
Feb 12 2003, 02:53 PM
Forget the Vellios. Use OEM parts. You will pay more, but it will also make replacing parts later easier and faster (oil lines)
I'm pretty quick with this stuff and it took me quite awhile to dig up the proper fittings and to make the braided lines for the Vellios tank. If you know you can buy a package deal with every fitting and braided line supplied..then I might think about it. Everything I hear is that Vellios is difficult to get products from right now. B |
fuch toy |
Feb 12 2003, 08:26 PM
Unregistered |
Try a914guy@aol.com he always has something around.....
campbellcj |
Feb 12 2003, 10:39 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
If I'm spending $6K+ to stuff a six in the car, saving $100 by using a repro tank does not give me a woody. As long as the factory tanks are still available (they are) I would lean that way.
If the Vellios tank isn't baffled (your post kinda implied that, I don't know myself) then that seems like a major negative. |
si2t3m |
Feb 13 2003, 09:15 AM
914 addict Group: Members Posts: 346 Joined: 9-January 03 From: Qc, Canada Member No.: 119 |
The vellios tank (at least the one i got) is baffled.
Someone out there already figured out the fittings needed. I bought my tank and conversion parts from Perry Khiel (sp?) a while back. Everything fitted like dad into mom.... (IMG:style_emoticons/default/blink.gif) Marc-Andre |
ChrisFoley |
Feb 13 2003, 12:11 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I say go with the factory tank.
Here is a pic of how badly the filter fit on a brand new Vellios tank I had. I had already mounted it in the car project I am currently working on. Found the problem while I was adding oil. Now I am waiting for the replacement. (IMG:style_emoticons/default/sad.gif) |
si2t3m |
Feb 13 2003, 12:24 PM
(IMG:style_emoticons/default/ohmy.gif)
Yikes! They treaded to hole for the filter fitting while holding the tank between there feet??? I do remember a fitting issue now... regarding the oil filler tube. Mine didn't want to slip in the tank as I think it should. The Id of the hole where the filler tube goes was a bit too small for the OD of the filler tube... Had to splice the tube a bit so it could go in. Marc-André |
Lo-Fi Version | Time is now: 17th May 2024 - 05:37 PM |
