Ra-Ra-Ra Put-Put-Put, This is what it sounds like |
adammtb |
Dec 26 2005, 04:12 AM
Member Group: Members Posts: 68 Joined: 24-September 05 From: Asheville, NC Member No.: 4,856 |
So we just installed our rebuilt engine and after sorting out a leaky carb, and a timing issue there are finally some signs of life. Although not too many signs because it won't start. The noise it makes is a ra-ra-ra-put-put-put where the ra's are the starter and the put's are combustion. It's like the engine catches but then dies after a few cylinders fire. We're running 34 ICTs on a 1.8 (formally a 1.7) with a Facet fuel pump running 4-7psi.
My initial reaction (after double checking the timing) would be to open the idle screws to allow more fuel. But it seems like if that works, then pushing the pedal down some during start up would work but it doesn't. Any ideas? Thanks Attached image(s) |
michelko |
Dec 26 2005, 05:21 AM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Try spraying some fuel direct in the carbs and see if it fires.
Check timing. no more ideas from me. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
DEC |
Dec 26 2005, 06:21 AM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
Joe Ricard |
Dec 26 2005, 07:05 AM
I went cross eyed looking at the picture but I think you plug wires are in the wrong order.
adammtb |
Dec 26 2005, 07:23 AM
Yeah, they were in that picture. It has since been fixed. |
Racing914six |
Dec 26 2005, 07:28 AM
Newbie Group: Members Posts: 37 Joined: 4-February 03 Member No.: 235 |
Double check the valve timing
Bleyseng |
Dec 26 2005, 10:02 AM
Now that you have the plug wires in the right order, check to make sure (take off the cap) and see if its timed right. Should be firing at about 0- TDC when after #1 intake valve has closed. If not, you have screwed up the installing the dizzy drive (common mistake).
(IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) |
JoeSharp |
Dec 26 2005, 10:27 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
goberserk |
Dec 26 2005, 04:34 PM
Newbie Group: Members Posts: 23 Joined: 26-November 05 From: Columbia, MD Member No.: 5,193 |
Yeah...we got it running...turns out that the timing was too advanced so after a bit of retard it fired right up.....guh, guh, guh, guh, guh, guh, guh, guh.
SLITS |
Dec 26 2005, 04:39 PM
I see you made it back from the "Exile Board" (pelicanparts).
Way to go (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (with getting it running). Small turns of the dizzy can do wonders. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:06 AM |
