> New fuel lines, best/easiest choice
914zim
post Aug 24 2003, 04:13 PM
Still pretty clueless...
Hey fellas:
I just pulled my fuel lines out this afternoon and they didn't look bad at all... (IMG:style_emoticons/default/mad.gif)
Oh well, so now I begin the effort to getting the new lines in. (IMG:style_emoticons/default/sad.gif)
I've scoured the archives and read about a few different alternatives of types
of lines to use.
The PP tech article talks about steel brake lines. I've heard copper is not
a good idea. I heard that the aluminum tubing is a good choice too. Aluminum
sounds to me like it might be the easiest to install, due to not having to use a bender. What about the original plastic type lines. I think I read this is NLA. Is this true?
This looks like a real bitch of a job anyway. Trying to fish the line through the grommets
without being able to see where you're going and that distance - yikes!!... (IMG:style_emoticons/default/sad.gif)
Is there a final word on what is the best and where did you get the supplies?
Also, any other tips and techniques from those of you that have done this before?
I've read dish soap to help slide the tubing...
Thanks in advance for any help!
Andy...
914zim   New fuel lines   Aug 24 2003, 04:13 PM
Brad Roberts   I'm looking into the black plastic lines that ...   Aug 24 2003, 04:24 PM
anthony   My '94 Jetta also has black plastic lines. A t...   Aug 24 2003, 05:00 PM
914zim   thanks guys!!   Aug 25 2003, 07:29 PM
ChrisReale   If you have a center console, remove it, and if yo...   Aug 26 2003, 12:32 AM
redshift   Whatever you do, stay away for those fuel lines Ar...   Aug 26 2003, 01:23 AM
Lawrence   Get: 60 inch brake line 90 degree fitting, female ...   Aug 26 2003, 11:01 AM
Pnambic   :clap: Great post Lawrence!   Aug 26 2003, 11:19 AM
Brad Roberts   STOP !! DO NOT USE LB'S method. It wi...   Aug 26 2003, 11:30 AM
Lawrence   Thank you. I check the line about once a week to ...   Aug 26 2003, 11:32 AM
Pnambic   whoooooa nellie. consider myself stopped....hadn...   Aug 26 2003, 11:35 AM
Lawrence   Brad, I don't know how much fuel line the FI ...   Aug 26 2003, 11:36 AM
Brad Roberts   I dont understand why people dont just pull long l...   Aug 26 2003, 11:39 AM
Brad Roberts   You said "brake line"... only semi 18 wheelers use...   Aug 26 2003, 11:41 AM
sharper   Now I am confused. Since I have to replace the fl...   Aug 26 2003, 01:32 PM
Lawrence   If there is nothing wrong with your existing fuel ...   Aug 26 2003, 02:35 PM
Brad Roberts   Has anyone even checked to see if we can still get...   Aug 26 2003, 10:13 PM
Britain Smith   Hey Brad, Are you saying that if you are running ...   Aug 26 2003, 11:59 PM
Brad Roberts   You will need to run no less than 3/8 inch line in...   Aug 27 2003, 12:05 AM
Britain Smith   Is there room to do that down the center tunnel? ...   Aug 27 2003, 12:18 AM
Brad Roberts   um.. have you seen the size of your tunnel ?? I...   Aug 27 2003, 12:28 AM
- Lo-Fi Version Time is now: 16th July 2025 - 03:41 AM
