914 left me stranded again |
McMark |
Dec 28 2005, 08:49 PM
Start with your coil. Andy just had this problem.
Howard |
Dec 28 2005, 08:54 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
And pull the plug on the '5th' injector to see if that helps. Mine went south when I first bought the car, stayed open and drowned everything.
gfulcher |
Diagnosis: Automobilitus. Prognosis: Terminal Group: Members Posts: 122 Joined: 3-January 04 From: San Francisco, CA Member No.: 1,501 Region Association: Northern California |
here's what I would do:
take off the FI system, replace with Dellortos. Enjoy the drive. Although, I do agree it sounds like an electrical problem, ultimately. With those FI systems, it could be anything, and troubleshooting on the side of the road isn't often a viable option. At least with Carbs, you know where you stand.. Good luck - don't give up - it is frustrating for sure - but once it's sorted out.. woohoo. -greg- |
pete-stevers |
Dec 28 2005, 09:30 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
mike just phone sher...tell her you have a deal that is to good for her to pass up...sell it to her to give to me for valetines day....good idea eh?
after all it is rust free isn't it? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) best o' luck steve |
rick 918-S |
Dec 29 2005, 11:26 PM
Hey nice rack! -Celette Group: Members Posts: 20,481 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
What's the verdict (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
bd1308 |
Dec 29 2005, 11:34 PM
not without changing that cam a FI engine with carbs = not efficient at all. b |
Gint |
Dec 29 2005, 11:38 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
It was only about 45 today with wind gusts up to 60 MPH. No garage space without moving a lot of junk (inlucing one 914/6 tub and two motors) out of the garage. Not much time either. Skeleton crew at work today. I decided to skip it until Saturday. |
Trekkor |
Dec 30 2005, 12:19 AM
Gint, sorry the car is not being your friend.
Sorry to hi-jack, I just can't let this slide. This is not true. I've personally seen/ridden in a car with a stock 1.8 with Webers and it was amazing. Beat near everyone at the a/x. Most people say a carbed motor on the stock cam will not make *more* power than a well tune F.I. set-up. I'm not even so sure about that. Hi-jack over...Start a new thread if you want to go on this. Sorry Mike... (IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) KT |
TROJANMAN |
Dec 30 2005, 11:17 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
mike, what time do you want me to come by and (re)move that tub and motor for you(permanently), so you have room to work on the budget car? (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) |
rhodyguy |
Dec 30 2005, 11:36 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you're crazy t (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) . you're right britt., and 2 x 32/36DGAVs would be 2x inefficient. but you would have dual webers. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
k |
TravisNeff |
Dec 30 2005, 11:43 AM
My first thought would be bad CHT
bd1308 |
Dec 30 2005, 01:38 PM
actually, you would no longer have the problem with the long intake runners and the lack of heat. It would be intresting to see how well they worked. Granted this still wont work well for a 2000cc engine, but for a 1700........... b |
Gint |
Dec 31 2005, 01:05 PM
I had a pretty good idea that knew what it was. I had been telling Sharon just a few days before it quit that the car felt like it was having less and less power at low rpm. The dwell was a little high when I installed the points when doing th etune up a month or so ago. I suspected my timing had changed or something was wronng with the points and that the dwell might be changing on me.
The dizzy was locked down tight and not turning (changing the advance), nor had it risen up and subsequently become disengaged. For grins I checked the coil for spark and found none. I have a new Bosch blue coil that I hadn't installed yet, so I temp'd it in... no joy. A check of the points revealed that with them on a dizzy lobe, they were still shorted. I loosened the screw and tried to open the points but they were still shorted. At this point I noticed the rubbing block had seemingly disapeared. Took the points out and low and behold, the rubbing block is broken at the base. I just happened to have a spare set of points on my desk. Stay tuned... |
bd1308 |
Dec 31 2005, 01:14 PM
this happened to me as well....the p-car mechanic didnt lube the dizzy cam and wore down my point block in like 1000 miles. I now have bosch dizzy grease.
b |
Gint |
Dec 31 2005, 01:38 PM
It didn't wear down, it cracked at the base. It's 62 and sunny, the top is off... I'm goin for a ride. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
bd1308 |
Dec 31 2005, 01:42 PM
allright! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) another one back on the road.
was the points a bosch brand or the mexico one? b |
Gint |
Dec 31 2005, 02:12 PM
Bosch, Brazil And I just put the same thing back in it.
Damn that was fun. I just terrorized a 5 mile radius. Gotta replace that glass pack with the stock muffler I bought. |
SLITS |
Dec 31 2005, 02:16 PM
Another testimony for Crane/Allison, Petronix/Compufire (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
JoeSharp |
Dec 31 2005, 06:07 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Mike: I don't have points in anything but spare parts.
:PERMAGRIN: Joe |
Mark Henry |
Dec 31 2005, 06:28 PM
Does it have a bosch coil? I've seen FLAPS coils melt that block.
Lo-Fi Version | Time is now: 6th June 2024 - 03:52 AM |
