REAR TRUNK STRUT CONVERSION, TRUNK SHOX |
TINCAN914 |
Dec 30 2005, 12:35 PM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
Ok I looked on CAMP914 web page and e-mailed for help, I even did a search, but no luck finding install instructions. I'm sure boxstr has not had a chance to look at my e-mail, only sent it a few minustes ago, but I don't want to stand around. I only have a few hours, so I need to get started. Anyone know if there is a classic thread or does anyone have experience in installling them? Pictures help.... Thanks
Lou W |
Dec 30 2005, 12:40 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Do you have a fax number? I'll fax you a copy of mine.
TINCAN914 |
Dec 30 2005, 12:48 PM
Lou, I don't.. I have the directions, but would like a little clearer pics.. I actually think I have it figured out. I'm not sure on the exact placement of the shox, in relation to mouting the bracket on the gasket tab. I have to cut the flash to mount the tab. I removed the factory torsion bars, so I have my trunk lid fully extended and held up by a tie down. How high should the trunk lid be? It appears that the shox are fully extended when I pulled them out of the shipping tube. So if I simply mount the shox to the trunk hinge, then that sould give me the location of the other mounting points. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Correct? |
Lou W |
Dec 30 2005, 12:56 PM
Yes, that is how I did mine, I located the 90 degree Mounting Brackets with the hinges just short of the fully extended location, I did my installation with the deck lid off, then I reinstalled my decklid.
Lou W |
Dec 30 2005, 12:59 PM
Lou W |
Dec 30 2005, 01:00 PM
like this;
Lou W |
Dec 30 2005, 01:01 PM
hjhk
Howard |
Dec 30 2005, 01:05 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Lou, that's the way I did mine, but only made the vertical cuts and bent the tab out of the way. Just in case 20 years from now some CW buys the car and wants to go original. |
TINCAN914 |
Dec 30 2005, 01:06 PM
EXACTAMUNDO!! That's what I figured, just wanted to make sure before I started driilling and cutting. Thanks Lou.. |
Lou W |
Dec 30 2005, 01:08 PM
klkl
Lou W |
ll;
Lou W |
Dec 30 2005, 01:09 PM
kjh
Lou W |
Dec 30 2005, 01:12 PM
Yeah, I see what you're saying, that's think ahead. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I did mine with a round shaped notch so that I can put some kind of rubber groment cut in half to seal the compartment. |
Eddie Williams |
Dec 30 2005, 04:24 PM
Senior Member Group: Members Posts: 822 Joined: 30-December 02 From: Nederland, TX Member No.: 55 Region Association: None |
I must have used a different kit, but I could have sworn I used the CAMP kit. I didn't have to notch anything.
Attached thumbnail(s) |
Carlitos Way |
Dec 30 2005, 04:29 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
From looking at your picture... your mounting bracket is to the rear of the hinge. Most of us with Craig's kit installed the bracket on the actual hinge itself. Couldn't say if it's Craig's kit or not, but if it works, use it! |
Eddie Williams |
Dec 30 2005, 04:32 PM
Must be a different kit, here's my bracket.
Lo-Fi Version | Time is now: 20th May 2024 - 07:10 PM |
